Question about Metra 2000 Chevy Tracker/Metro/Prism
1998 chevy metro makes a noise in the front end when you turn it to the right and accelerate. The noise quits when the wheels are in any other direction
    Sergeant:
    Champion:
  • 255 Answers
Check tie rods by jacking car up and moving tire side to side.
check ball joints by moving tire up and down.
Posted on Sep 07, 2009
It starts In 3rd and when in 5th while still accelerating, a noise which sounds like it's coming from drivers front side, the best I can describe it is it sound like a commercial paint shaker shaking a...
Noises from axles can be really deceiving. The sound is transfered throuh the transaxle and can resonate through the entire vehicle. The turning to the left thing makes it sound like a problem in the right wheel/axle area. Wheel bearings and axles tend to make worse noise when they are on the OUTSIDE of the turn. More of the vehicle weight is shifted to the outside due to centrifugal force. Thus, if the noise is louder when turning left, this puts the right axle to the outside of the turn and the most likely to be the source of the noise. (and vise-versa) The fact that the noise calms down while cruising makes me believe that it is not a wheel bearing. Wheel bearings can make more noise in turns, however, they usually make a "roaring" or loud "humming" noise that gets louder with speed. An axle is more likely to change or get louder according to engine load more than rotational speed. (Way worse while accelerating or climbing a hill) I would be taking a hard look at the right axle.
Jan 25, 2011 | 1997 Geo Metro
My car sounds like an airplane when i accelerate over 35mph. when i make right turn on a curve it stops but when the steering wheel is straight the car continues to make the noise and when i turn left the...
Sound like a bad front wheel hub bearing, if you can jack up the front end of your car and turn the front wheel's and listen for the sound or take it to a repair shop to have it check, if not taken care of will cause more damage to your car.
May 11, 2010 | 1996 Dodge Stratus
1998 chevy cavalier 2.2l wheel noise
usually if noise is made when turning right it would be the right wheel bearing easiest way to check would be to lift the car off the ground on that side until tire clears the ground and spin the wheel to see if it makes noise also try grabbing the wheel on the top and bottom at the same time and see if you can move the wheel back and forth checking for slack.
Aug 24, 2009 | Chevrolet Cavalier Cars & Trucks
98 Cavalier Makes loud vibrating noise
sounds like another bad hub brg, jack up front end and check for play in wheels from top to bottom wiggle for movement. A loose wheel brg will set a front speed sensor code.
Jul 30, 2009 | 1998 Chevrolet Cavalier
Front end noise in chevy metro
yes it is possible, it is possible the rotor was not turned properly and it is out of round but it is also possible the hub bearing on passenger side is going out also.you should lift car and ssee if wheel is flexing up and down and side to side
Jan 18, 2009 | 2000 Chevrolet Metro
98 Chevy Lumina has front end noise (rumble) from 10 mph and above. It gets increasingly louder as you accelerate. It does not change by coasting or applying the brakes. Also does it in reverse but not...
I may be a wheel bearing. Try shifting the weight of the car on the front tires by turning the wheelslightly while driving about 30 MPH. Don't turn enough to change lanes, just enough to put the load on the outside bearing. It may quiet down in one direction. The failed bearing is generally the side that you turned to in order to make the noise go away. Say the noise goes away when you steer to the right, the failed bearing is usually the right one.
You can also check for play by jacking up the car and shaking the tire. There should be no play.
Sep 06, 2008 | Chevrolet Lumina Cars & Trucks
Metra 2000 Chevy Tracker/Metro/Prism Logo
143 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
