Question about GE Refrigerators
Water will not flow out of dispenser
Water will not flow out of dipenser
    Problem Solver:
  • 15 Answers
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Posted on Sep 08, 2009
Continuous flow from water dispenser
With GE it could be a bad water valve, bad microswitch that actuates the water or could be a bad main control board. You can diagnose the valve by simply pulling the wire harness off and turning the water on. If the water starts to flow with the power removed from the valve then the valve is stuck and needs replacing. If the water stopped with the power removed, check the valve's wire harness with a volt meter and see if 115vac is being applied. If so then the switch or the board are bad. You can check the switch by setting your meter to continuity and checking the com part of the switch to either the no or nc part. One should test good for continuity, the other not and with the switches buttong depressed the exact opposite. If the switch test good then the board is bad.
May 27, 2012 | GE Refrigerators
On my lg tromm. My softener dipenser will not work. It still has softener in it.
You may have a problem with one of the water valves not dispensing water into the softener dispenser. You will need a technician to check it out for you.
Jun 16, 2011 | Washing Machines
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Ice maker dispenses ice but the water dispenser does not dipense water help!
the water line may be frozen / if so you can adjust the tempt and in 24 hr it may start working / if that does not correct problem ck the dual valve as the water side may be burned out .. mm
Jul 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dipensers drips
replace the water disp solenoid,its located at the back of the fridge where the water line connects
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
My bosch classix washing machine is not dispensing the fabric conditioner properly. Often the fabric conditioner is left in the dispenser unused, just now it went in with the washing powder. It has...
The water going in to the dispenser is blocked by sludge.
Remove the dipenser tray.
Look up inside the tray hole, at the 'roof' of the tray hole, and there are four holes (square on my machine) where the water flows in - in the middle of the 'roof'. These will be blocked with sludge. Try to poke them clear with a nylon tie or plastic coated wire - should go in a few inches.
It worked for me.
Aug 06, 2008 | Washing Machines
Fridge is leaking
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Oct 15, 2007 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
249 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
