Question about Garden
Need wiring wiring diagram for an older MTD k247c,
Need wiring wiring diagram for an older MTD k247c Silver Series , no power to key , have checked all safety switches, I think I may be missing a switch, motor will run if jumpered, where can I obtain it?
  • rattosh51 May 11, 2010
    Have you checked the MTD website?
SOURCE: Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Posted on Oct 04, 2008
Benimur
  • 6966 Answers
SOURCE: 2002 kawasaki ninja 250 motor on ATV need wiring help
Hi and welcome to FixYa,
To my knowledge, there would only be 3 wires needed from the handlebars that affects the engine:
  • engine RUN/OFF;
  • clutch ENGAGED;
  • engine START.
The first 2 would go to the interlock plus the neutral wire and the sidestand wire. The interlock then sends signals that starter motor can turn and that CDI can fire.
As to the ignition coil, 1 wire is IGN B+12 while the other would go to the CDI and should pulsate when cranking or engine running.
Good luck and thank you for using FixYa.
Posted on Feb 01, 2009
jasonnash197
SOURCE: charge-run wiring diagram 1982 Yamaha 650 4 cly & 76 Kaw 750 twin
1982 yamaha 650 maxim coil problem
Posted on Apr 04, 2009
  • 153 Answers
SOURCE: I have a toro 8-25 rear engine rider model 56172
None of the numbers you supplied match any info on the toro.com web site. Check the numbers and then see if toro has any info for you.
That said, it sounds like you connected to the wrong relay terminal. Here is how you want it connected:
The battery (and alternator) connect to one of the large terminals on the relay. The starter connects to the other large terminal. The start switch connects to the small terminal on the relay. The idea being that the small current connected to the small terminal turns on the relay which connects the large battery current to the starter.
Obviously there is more to the wiring than just that, but you didn't ask about the rest...
Posted on May 05, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
Did you check the fuse?
Posted on Jun 24, 2009
Need a wire diagram for my mtd 20hp lt lawn tractor
use your model number under the seat.
go search for a manual.
there you will find what you are looking for
Oct 18, 2014 | Mtd Garden
Mtd wiring schematic
I will be happy to assist you with locating the wiring diagram for your MTD 990. Great machine by the way. The full manual may be downloaded at the following site; Page 26 of MTD Hydrostatic Tractor Owner Guide ManualsOnline com by clicking on the little arrow that is pointing down above the displayed page. Here is the
If you need any further assistance, please let me know.
Jun 29, 2014 | Garden
Ignition problem
Check if the small wire on the starter has power with the key held in crank position. If battery voltage there, either bad battery cables or connections, or the starter solenoid has a malfunction. If no power when key held in start, it could be the safety switch (a clutch interlock switch on manual transmissions, or a park/neutral switch on automatics). You may need a wiring diagram to see the start circuit from ignition switch to the starter solenoid-some have a start relay in that circuit.
Find wiring diagrams at http://www.bbbind.com/technical.html
Free TSB's and wiring diagrams for every make and model.
Feb 09, 2014 | Cars & Trucks
Mtd riding lawn mower with B & S engine i need diagram of wiring harnes conections etc.
Most owner's manual have a wiring in them. I'll try to send you a my picture. See you later.
Dec 20, 2011 | Mtd Garden
I have bought a new alternator for my 1967 ford bronco an its still not giving charge to the battery an i have full power to my wires an everything i was thinking that i might of mixed up the wiring but...
Hello, Check your small wires to the Alternator plug for power using a Testlight or Voltmeter. If the Alternator does not get power, it can't boost the power. The wire runs through the Ignition switch and is dead to the Alternator when the key is off.
Some of the older models used a fusible link and it was around the Battery. Corrosion could break the connection. You are going to need an older diagram for its location. Sometimes you can get help at a Ford Dealer Parts counter. The Parts guys can print you a portion of the shop diagram right off their computer screen. They are usually very helpful and it is free.
Your older model may have an external Regulator. That would be a possibilty for a crossed wire with the Field wire. Most of the Ford diagrams have the color wire shown on the print.
Sep 13, 2011 | Ford Bronco Cars & Trucks
Can i have a mtd pro 800 series drive belt diagram please
Cant find the diagram without more info but if you go to the link I have here and enter your model and serial number it will supply you a manual and it will be there. If you need further help please contact me. thank you.http://manuals.mtdproducts.com/mtd/Public.do
Jun 07, 2011 | Mtd Drive Belt 42"
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
