Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
The spinner wont spin
The red spinner will not spin what does this mean
    Sergeant:
    Champion:
  • 255 Answers
Clog, take bottom apart and clean, keep cleaning it theres more in there
Posted on Sep 07, 2009
  • 30 Answers
Could be a broken belt. Usually $5-$15 bucks at your local super-store. Fairly easy to fix too.
Let me know how it works for you.
Why the spinner of the weed eater doesn't spin
Check to see if the drive belt or gear(s) is (are) lose or broken or if the spinner is stuck due to an obstruction. Replace or repair or clear the obstruction. If not get professional service.
May 20, 2014 | Vacuums
Ths spin scrub brushes wont spin
Be sure the speed switch is set to carpet. Also remember the brushes won't turn until the handle is tipped back. If this is not the problem, remove the brush and insert a flat screwdriver into the square hole the brush pin goes into, and be sure it turns ( there will be some resistance ). If it is seized up, the turbine will need replacement. There is also an air intake screen which must be kept clean. It is located behind a clear plastic cap on the upper front of the floor nozzle, just above the brush "spinner".
Feb 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Flow indicator does not spin when the trigger is depressed like nothing is coming through, pump?
Usually that is showing no soap in soap tank even if there is water in the water tank.After filling soap tank make sure it locks in real good ;Thats been my problem a few times.I didnt know the water and soap were in seperate tanks the first 2 times I used mine lol....
Jun 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
The thing that is suppose to spin to show it is working is not spinning.
Are you getting fluid out when you spray? If not, check that you are not out of cleaning fluid or water. Assuming that you are not out of the cleaning fluid, you can remove the cap that holds the spinner and see if something is obstructing it. If you remove the cap and try to spray cleaning fluid, it should come out of the hole. Be careful if you do this as it sprays pretty far (put a towel over the hole where the spinner goes and watch your eyes). If fluid is coming out, it's just the spinner that is hung up. Mine does this sometimes. Good luck!
Mar 10, 2010 | Bissell 1699 ProHeat Clear View Upright...
The spinner bush turns really slowly. It doesn't
u need to get a new belt. a local hardware store or walmart carries it. also u need to take the vacum apart further so u can clean out where the motor spins u will get much bettter results
Oct 06, 2009 | Eureka Vacuums
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
The water does not shoot out of my bissell proheat shampooer. The red spinner has stopped spinning.
I'm not sure I have the same kind of machine as you because I don't think I have a red spinner. However, I did have the problem of water not shooting out (although the solution was being used up, just not the water). The problem turned out to be the plug underneath the main tank. To find out if this is your problem, lift out the main tank and take it to the sink. Feel underneath for the plug. Push inside of it. Water should squirt out (assuming there is water in your tank). If it doesn't, turn the tank over, unscrew the plug, and push the thing inside until you get it to spring up and down. If it won't do that, you might need a new one. If it springs, screw it back and try your machine again. Mine worked good as new after I did this. Good luck!
Dec 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
384 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
