Question about QSC RMX-2450 Car Audio Amplifier
Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
It has been an awesome amp in the past. This just started at the last gig.
I noticed Channel 2 started sounding crackly the last gig I used it at. Now Channel 1 still works fine, but Channel 2 hardly does anything and it sounds bad. The clip light for channel 2 is on soon as it powers up the amp.
I hope the amp is not bad now.
Overtime DJ Service
    Guru:
  • 1,326 Answers
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Posted on Sep 14, 2009
My QSC 1500 LOUD speaker won't turn on why?
I've had QSC power amps with internal fuses in the AC power section, and I have seen the fuse holders separate from the board. These were the 2-piece (per fuse) clips that solder to the board and the fuse clips into them. I'm not sure if you are talking about a speaker, a power amp, or a powered speaker, but if it doesn't power up at all, it's probably in the AC Power Supply area.
Jul 25, 2014 | Audio Players & Recorders
Soon as turn on my qsc mx 3000a ch 1 keep clip and ch 2 playing
It is seeing an overload of resistance. Check your speakers to see if they are within tolerance of stated ohm factor.
May 13, 2014 | QSC Car Audio & Video
I need the schematic for QSC RMX2450
HI,
if you can provide your email address the i will sent you the schematic diagram . Its not possible to upload PDF files here.
Ajin
Apr 30, 2013 | Audio Players & Recorders
Amp 5050 rmx stay in clip mode
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
Sep 22, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
My QSC PLX 2502 amp completely blew. Channel 1 has been giving me problems for a year and I have had the amp about 3 years. This past week it drove into the red so much and I could not stop it. Well now...
You should NOT drive the amplifier into the clipping mode continuously. There is a possibility that you have fried your speakers or that they are the real problem. You haven't told us what you were driving, however this amp will deliver 450 Watts per side RMS at 8 ohms which means your speakers have to be rated at least that much RMS power for continuous. When speaker voice coils fry, they can wipe out amplifiers. Let us know what speakers you are using and how they are configured. This amp is going to be expensive to repair I can tell by looking at the schematic: Here is the schematic:
http://elektrotanya.com/qsc_plx2502.pdf/download.html
Scroll down to "get manual" and click to download it. IGNORE other download links.
This amp has circuits to boost the power supplies to the amps to handle the peaks. It is rather complex but the schematics are complete and have good explanations... some of the best I have seen. There are going to be a lot of destroyed components and great care has to be used after repair to "cold start" the unit to make sure nothing else is bad or it will blow up again. Most people do NOT have trouble with the QSC amps... so do tell me what speakers you are using and how they are configured so we can verify the design is correct. This amp is rated for 8 ohms so USUALLY only ONE speaker can be connected per side... and finding an 8 ohm speaker that can take 450 watts continuous RMS isn't easy. People fall for the advertising claiming "Peak" and "Program" power which are FAKE advertising... ONLY use continuous RMS power when sizing amps and speakers. There are MANY ways to cook out equipment... One is to boost the bass or the treble way up. Another is to NOT use balanced interconnect lines between mixers and your amps. Yet another is to NOT power ALL interconnected equipment from a single receptacle or power conditioning module. Please describe your setup further so I can help you more!
Sep 20, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
I recently dropped my amp after a gig and once I hooked it back up only one channel works. I noticed upon start up after the fault lights go out I would hear two clicks .. now I only hear one. I'm...
I am a musician myself (classic rock band) I too have a crown two Chanel amp , only difference is ours is a 3000. Well don!t feel bad. I had dropped mine more than once and your right, when you turn it on you hear two clicks, one for each side, those are relays that trigger the power to come on and like warm up. I dropped mine one time and both sides were not clicking at all, so I took it apart ( lid off, unplugged of course) located the relays which were pretty easy to find as they were the first switch from where the internal power plug comes in, I moved them around, got lucky, they got loose from when I dropped. Then happened again by a helper, and this time no help. Went to guitar center and they took unit and replaced them, about 40 bucks. That was a couple years ago. Point of my story, this problem seems as mine, and I believe it is going to be a loose or broken relay for that side chanel. Thanks mike, hope this helps.
Sep 01, 2011 | Crown CE1000 2-Channel Amplifier
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
Behringer amp
Hello pare ko.
EP2500 is a pro amp, manufacturer says that. Notorious to me.
Got 5 of these for repair. Clip is of course cause by too much
signal from source. If the amp is still clipped or on protect even w/out
signal in, time to open and do repairs inside. usually a MOSFET
inside P50N06 (50V-60A) is kaput. or MJE15033G and MJE15032G.
Now if blowing main Fuse, main txistor 2SA1943/2SC5200 maybe gone.
Read carefully the setting of your dip switches setting at the back.
This amp can drive 750 watts/ch@4 ohms.
Good Luck From Siliconchip
Nov 11, 2007 | Behringer EUROPOWER EP2500 Amplifier
Need schmatic for ep2500
check preamps small parts! maybe you have change value capacitors and resistors!
Sep 13, 2007 | Behringer EUROPOWER EP2500 Amplifier
QSC RMX-2450 Car Audio Amplifier Logo
700 people viewed this question
Top QSC Car Audio & Video Experts
xxxxxx xxx
Are you a QSC Car Audio and Video Expert? Answer questions, earn points and help others
