Question about Dual XNP653 3-Way illumiNITE 6-1/2'' Speakers Car Speaker
How to connect the 12 volt DC to the illumination lights from the tweeter
1) light have 2 wire R./B.
take R n connet with other B .n 2 wire r there two join too dc okk/............
Posted on Sep 09, 2009
  • jitu chavan Sep 09, 2009
What cause battry to die over night?
If test light is a 12 volt light tester AND ILLUMINATES BRIGHT it shows that a component is actively trying to complete a circuit and yes drawing power causing a drain on your battery, now if test light illuminates low, possibility could just be ecm memory or antitheft system active . either way this test should only be done with a 12 volt test light as if you use a 5 volt (computer friendly) tester , false light will have you chasing a ghost. trust me. that trick helps by checking for parasitic draws a 12 volt tester does not illuminate when keep alive memory voltages are present . those voltages are not enough to drain over night. good luck
Nov 28, 2017 | GMC Cars & Trucks
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
How do I connect the lights to get them to work? what to plug into for power?
Not enough information. What lights are you wanting to connect 120/220 ac volt or 12 dc volts lighting?
Mar 30, 2014 | Parker House Portofino Space Saver...
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
I have 3 landscape lights that were working but quit working in a system with about a dozen other lights that continue to work. I presumed the bulbs needed replacement but that didn't help. I verified...
My experience has shown that this is nearly always a connection and/or wire corrosion issue. Be certain that all connections are clean-if not clean with fine grit sandpaper or replace. Remember these devices are exposed to the weather on a continuous basis.
Nov 04, 2013 | Intermatic Malibu 300W Power Pack...
How to install 12 volt led light bulbs in the 220v Power Supply
Buy a lamp holder and 220V AC to 12V DC power supply, power supply should exactly be connected with the positive and negative holder, plug in the power, 12 volt led light bulbs can be used.
Dec 01, 2011 | Cars & Trucks
My capacitor is not charging the way it was described in the ownwers manual. it works and seems to enhance my stereo and bass response however i still get dimming lights when t urned up to high volume
Your Ground wire has to be within 12 inches of the power cap. Also the power connection needs to be connected directly to you car battery. If this is correct and you still have problem your power cap could be bad. You can also connect a multimeter to the power and ground connections on the power cap and test DC power with the cap not connected to the car .You should get at least 12 volts DC on your multimeter. Hope this helps.
Mar 12, 2010 | Boss Audio CAP10 10 Farad Digital...
I have a 1999 Dodge Ram, I just replaced the
Why this isn't a total solution, one resource I've used many times when it comes to electrical diagrams is http://www.the12volt.com/. They have all the diagrams and "audio experts" there that might be able to tell you specifically the color.
Jul 05, 2009 | 1998 Dodge Ram 1500 4WD
Dual XNP653 3-Way illumiNITE 6-1/2'' Speakers Car Speaker Logo
77 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
