Bosch Nexxt  100 Series WFMC1001UC Front Load Washer
Problem for Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Cycles take an exceedingly long time to complete
By robcathjeffe on Sep 07, 2009
I have a Bosch Nexxt 100 series washer, and the wash cycles are taking anywhere from 90 minutes to 2 hours to complete, which is ridiculous. This happens regardless of how much laundry is in the washer but the loads do take a lot longer if there are towels in it. Is there anything we can do to reset the timing or something so that the cycles don't take so long to complete?
Solution #1
posted on Sep 07, 2009
Not Rated)
carputers
Rank: Wiz
Rating: 80%, 101 votes
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Was this helpful?
Yes
No
Popular Solutions for Bosch Nexxt 100 Series
Questions and Unsolved Problems for Bosch Nexxt 100 Series
Do you recommend Bosch Nexxt 100 Series WFMC1001UC Front Load Washer?
Answer
Answer
The spring held wire holding the rubber gasket around the front opening of my Bosch Nexxt 100 series... (More)
Answer
the washer will fill up with water then set thru the wash cycle empty out the water then add water... (More)
Answer
It sounds as if something has gotten stuck in the washer such as maybe a hair tir with a metal clip.... (More)
Answer
I have a bosch washer about 3 years old. It suddenly stopped on spin cycle and water would not drain... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
