Question about GE WSXH208A Front Load Washer
The lock button is stuckl and I cannot open the
The lock button is stuck! and I cannot open the door eventhough I have attempted to turn off the power and unplugged it. How do I get the door to release?
  • 15,935 Answers
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
(Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 07, 2009
  • 99 Answers
Try Resetting the Lock by Turn off the washer or dryer .. press and hold down the lock button while powering it back on . Once it's on let go see if this corrects the problem
I have a 95 saturn 2 door, the passenger door is stuck closed. The power lock triggers but still wont open from inside or out. Please help!!!
This usually works.
Take a rubber hammer,roll down the window,then manually unlock the door using the inside unlock button (not the power lock button) while you give the door a good whack about half way down where the door lock assembly holds the door closed to the car body.It may take a few whacks and a few lock/unlock cycles but this usually allows the lock to release and you can open the door.NOW.....take off the door panel and lube that lock assembly and don't close the door unless the lock can be locked and UNLOCKED.
Apr 20, 2017 | Saturn Cars & Trucks
Door is loked on rear driver side want open
Won't open from outside? Won't open from inside? Equipped with power door locks? IF so, and won't open inside/outside, suspect stuck power door lock actuator. Sometimes working the lock/unlock button will make the door unlock. If not, the door will require disassembly from inside to determine what the failure may be. If the door needs disassembly while in the closed position, the paneling/clips may get damaged FYI
Dec 22, 2015 | 2001 Chevrolet Lumina
Door lock is stuck closed cannot shut door?
Good Morning Richard, thank you for your inquiry!
Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
Mar 23, 2015 | Frigidaire Ovens
Power locks stuck.... After a cold Christmas day,
should like water has frozen inside the door on the mech, its probely released by now , or water has cause a short in the door electrics
Dec 26, 2009 | 2007 Kia Sedona LX Minivan
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Oven door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Feb 17, 2009 | Frigidaire FEF336BC Electric Kitchen Range
My Sharp copier gives a CH error when turned on.
One of your doors is not shut all the away or dv unit is not installed.
Feb 12, 2009 | Sharp AL 1631 Copier
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
GE WSXH208A Front Load Washer Logo
115 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
