Jenn-Air JMC8130DD 1000 Watts Microwave Oven
Problem for Jenn-Air JMC8130DD 1000 Watts Microwave Oven
The power went out on the microwave
By amziomek on Sep 07, 2009
The power went out on the microwave. We were cooking potatoes in there, and it just went dead. We were using the Jenn-Air oven below it at the same time, but that is still working.
Solution #1
posted on Nov 24, 2009
Not Rated)
bunyil
Rank: Apprentice
Rating: 0%, 0 votes
There's a circuit breaker behind the microwave. Yup, that's where
they put it, believe it or not. The microwave and the oven are joined
together so you have to pull both of them out to get to the circuit
breaker. There are screws that hold the microwave and oven to the
cabinet it's mounted in. There should be 4 around the microwave
door and 6 around the oven door. The oven door needs to be
removed to get to the 2 bottom screws. The oven door has a metal
tab on it's 2 hinges that must be pushed down to unlatch the oven
door hinges from the 2 (per side) posts that the oven door pivots
on to open and close. After the door has been removed you can
take out the last 2 screws, you should also remove the vent at
the very bottom of the oven by removing it's 2 screws. Make sure
you have a least 2 strong people to pull the whole unit out, it's
also a good idea to have something sturdy that's the same height
as the bottom of the oven to rest it on after you pull it out. You
don't really have to pull the unit completely out, but it helps. You'll
see the small circuit breaker on top of the oven at the rear of the
microwave, just press it to reset it. Putting the unit back in the
cabinet is the reverse of the removal, but be sure you don't pinch
the armored conduit that contains the gas line for the oven. It'll
probably want to fall behind the oven as you push it back into
place like it did at my friends house. What we did was I pulled it
up and held it at the back of the microwave while 2 guy's pushed
the unit back in. Fortunately, it stayed in place after they pushed
it part way in and I had to pull my arm out of the way. It's a really
crappy place to put a circuit breaker for the microwave. I mean,
come on! You couldn't put it under the microwaves bottom cover
plate? There's room for it there! Anyway, that's how it went at my
friends house. I hope this helps you fix you're problem.
Was this helpful?
Yes
No
Solution #2
posted on Sep 07, 2009
Not Rated)
cksocialc657
Rank: Apprentice
Rating: 100%, 1 votes
in some microwaves there are overheat sensors, if it does not work after it has cooled down do not attempt to have a look inside unless you have ben trained on microwave repairs, in some cases the unit can hold a enough of charge of electricity to kill you.
take it to a trained engineer...if it's a cheap one...just buy another
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JMC8130DD 1000 Watts
Questions and Unsolved Problems for Jenn-Air JMC8130DD 1000 Watts
Do you recommend Jenn-Air JMC8130DD 1000 Watts Microwave Oven?
Answer
Answer
how to set power levelto 1000 in the Jenn-air microwave
Answer
by turning on the light comes up the sound of running is not coming nor it is warming up
Answer
Everytime we turn on the air here a smell comes like something is burning but we dont turn on the... (More)
Answer
How do I get to the fuse on a Jenn-Air Microwave oven Model JMC1830DD
Answer
My husband waaayyy overheated an oatmeal bar and smoked out our entire house . . . the microwave... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air JMC8130DD 1000 Watts...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 2519
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
