Question about Panasonic PT-47WX49 47" Rear Projection Television
Blurred image on panasonic tc21p50r
I got blurred image on the screen, the audio is excellent, both tuner and av inputs. except the blurred image.thank u .
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 10, 2008
Distorted images
Hi Dong,
i think problem is with your tuner section.
please try with av input with dvd player.
if it works fine you need to repair your tv .go for the good electronic repair shop.
regards.
nuwan.
Jan 10, 2014 | Samsung LN32A330 32 in. LCD TV
Panasonic TH42PX5w has no picture only menu
if no image via rf and av jacks it is not the tuner
Mar 18, 2012 | Panasonic Televison & Video
How to I change the video input? i.e. I got a digital TV box and need to put it to video input 1. How?
  • On the back of your TV are all your inputs/outputs.
  • On the far left is your Video 1 Input.
  • The top input is your Video (Yellow AV cord)
  • The middle input is your Left Audio (White AV Cord)
  • The bottom input port is for your right Audio (Red AV Cable)
  • After you have all the AV cord up as I have explained then push the "TV/Video" button on the remote until "Video 1" appears on the screen.
  • In the event you should want to use Video 2 sometime then hook the cords up the same way except in the Audio 2 port in the back of the TV.
  • Each time you press the "TV/Audio" button you will cycle through the Inputs until you come back around to TV.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Panasonic CT-32SL13 32" TV
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
Hi, my Nakamichi Av 10 receiver tuner and the video AUX section is dead and does not work except for the Tape in
I am facing the same issue All Analog inputs except for Tape in does not work and the tuner does not work on my Nak AV-10
Jun 03, 2010 | Nakamichi AV-10 Receiver
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
The av on my panasonic tv is the same as whatever channel i have on when i press the av button. is there a way to fix this? the reason is i just got a ps1 console and although it semi works the picture is...
Your problem is internal, there is a i.c inside the set that selects the input when asked to(input selector).now it seems it has the door wide open for the tuner but still tries to open video.there is not much you can do except get help from a tv repairman. good luck
Nov 03, 2009 | Televison & Video
Philips 32PFL5322D/37 Black w/any of the analog inputs. Tuner ok
WHEN IT BLACKS OUT, GENTLY PUSH OR TAP ON THE SCREEN. YOU SHOULD SEE A SLIGHT WHITE DISCOLORATION WHERE YOUR PUSHING. IF THIS HAPPENS YOU PROBABLY NEED A MAIN TOTAL ASSY. DO YOU STILL HAVE AUDIO WHEN IT BLACKS OUT?
Sep 25, 2009 | Philips Televison & Video
Help!!
Do you have your other components wired to the Onkyo. The monitor output isn't the best way to go. If your TV has component inputs or an HDMI you should run one of those instead, running a composite video cable will only get you analog at best.
If you are content with running analog you may need to go into the menu on your tv and select the type of video input you are using. The same goes for your receiver, switch the output to analog out.
Jul 17, 2008 | Onkyo Audio Players & Recorders
Image went out and now i see small blur in the middle
does the blur goes across set? Or is it round in the middle?
Oct 07, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
