Question about Magic Chef MCWC16MCG Wine Cooler
Light flashes on and off, and fridge does not work
The fridge worked great for about 2 years, then one day it started clicking on and off. I tried turning the fridge off, and on...didn't work. I tried leaving the fridge off for a while, then turning it on...clicking. And I tried leaving it unplugged for a while, then turning it on...clicking.
I am disappointed to see so many other people having the same problem.
    Sergeant:
    Champion:
  • 255 Answers
Relay at compressor plug is bad, replace compressor relay
Posted on Sep 07, 2009
  • 99 Answers
Lamp loose connection?
Try using a different bulb ?
Have to slam freezer door to clear 88 error codes on samsung refrigerator
I am not certain on this, but my guess is that you have a problem with the door closed sensor, which should be attached to the door/ light actuating button. It may be faulty, or just out of adjustment. I assume that you have contacted Samsung about what error code 88 is. Do they have any other input? What doesn't make sense is that the fridge turns off. You would think that if the door sensor read "Open door" it would continuously run, rather than shutting off, unless it is causing an overload, or overheating condition. I have had good luck w/ Samsung tech dept., but they can be a little hard to reach. Hope this helps.
Mar 10, 2014 | Refrigerators
Refrigerator temp erratic
you will have to replace your thermostat of the fridge
you can find it near the light inside the unit
Sep 17, 2008 | Samsung RS2534 Side by Side Refrigerator
We have a Magic Chef MCWC52B
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
Nov 30, 2007 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a amana abb2223deb fridge and the freezer stopped cooling then 2 days later the fridge stopped as well.Any one know what that can be I bought this in 2005 my second fridge in 7 years. any help would...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 29, 2010 | Amana Refrigerators
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
My refrigerator does not cool any more. I put it OFF for one hour now and there is no frosting. I checked all the grids and there is no ice etc in the fridge. It is a Inglis Side by Side 2 door fridge...
Check the cycle timer this is usually 90% of call outs for this issue. They are usually locate inside fridge on the top by light ( some times on the lower outside back of unit). Put a flat head screw driver in and slowly turn until you hear a click and compressor should kick in. If this works you will have to replace timer or it will freeze up in several days but will keep you cooling until then. Good luck!!
Apr 11, 2017 | Jenn-Air JCD2292KTB Side by Side...
HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Jul 21, 2009 | GE Refrigerators
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Clicking noise-GSH22JFR/SH200106
If you have a 5 year warranty, you should not take anything apart and consult the place where you got the appliance.
They should be able to tell you exactly what is covered under warranty before they work on it.
Feb 20, 2008 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Magic Chef MCWC16MCG Wine Cooler Logo
321 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
