Question about Microwave Ovens
Fan will occilate but not spin freely - Microwave Ovens
  • William Miller
    William Miller May 11, 2010
    Is it possible that the blade assembly has come loose form the shaft. If so, a spot of super glue on a clean shaft will usually take care of that. Otherwise, please contact me directly with your brand and full model number from the tag on / in the unit
    and more specific details of the trouble you're having so we can help you with free do-it-yourself tips and/or an estimate. * * * * * NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for FREE help & do-it-yourself advice.
    William E. Miller
    prototech@usa.net http://www.microwavedisplay.com
    Scholar:
  • 178 Answers
If the fan just sits there and can't decide which way to turn, the motor is bad. I'm assuming that it is a 120 volt, 60 cycle motor. Double check the voltage to the motor and the frequency as well before condemning the motor.
Posted on Sep 14, 2009
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
Turntable will not revolve
Hello
Inspect the turntable base wheels and guides. If they are gummed up with food or other gunk, they will not turn and the turntable will not rotate. Clean as needed.
Remove the microwave case by unscrewing the casing screws with your screwdriver. Locate the turntable motor which will be directly beneath the oven floor.
Inspect the belt that connects the motor to the rotating table. If the belt is broken, replace it.
Touch the probes of a continuity tester to the electrical contacts on the motor. If the tester lights up, the motor windings are good, which means the motor is functional. If there is no light, the motor needs to be replaced.
Check the wires leading from the cord to the motor itself. Look for any breaks in the wire, or a wire that has been pulled off of any electrical connection. Any connection that has been compromised can be soldered back into place, but if the cord is damaged at all, it needs to be replaced.
Attempt to spin the motor by hand if the continuity is good and the belt is in place. It should spin freely, but if it is difficult or doesn't move at all, you will need to lubricate the bearing. Either apply spray or bearing lube to the motor axles to solve this problem, and allow the motor to spin freely once again.
Oct 04, 2011 | Panasonic NN-S952 Microwave Oven
Microwave turntable won't revolve
Hello
Oct 04, 2011 | Microwave Ovens
Turntable won't revolve
Dishwashing tablet (the cleaning aid) stays dry during whole cylce.
The large arm that circles the top part of the washer should spin freely. I suspect a knife or fork has slipped and stopped it from turning.
Hope that helps.
Feb 27, 2011 | Microwave Ovens
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
G.E. convection oven fan stoped working. The fan turns freely with no resistance.
Does it have 110 volts on it? If so its bad.
If not then look for a bad relay.
Jan 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
If it is the magnetron cooling fan, it should be a one-speed type.
Assuming your AC line power is correct (110-125VAC) then the fan may be bad, or there may be a problem with the relay on the control board or indeed a bad connection in the wiring.
The way I would test it is to disconnect the fan and the connect a line cord directly to it.
I've uploaded the wiring diagram to my site at:
http://207.234.249.73/mwd/mmv5000_wiring.gif
If you think it's the control board, we repair these for $39.95 in most cases.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 07, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
