Installation 2-nd HD
I put in my Dell XPS400 2-nd HD Seagate 320GB SATA, cabled and got Device Manager: ST3320620AS but cann't see on My Computer.
What I have to do?
  • Felixs Dec 09, 2007
    You are real help me.
    Thank you very much!
    Felix
  • 67 Answers
Hi i also have a dell xps 400 what you need to do is enable sata 1 on the bios and then reboot ( if you havent already). Then if you have windows xp click right on my computer and select manage,it opens up computer mangement, then go to the tab called storage and on the sub menu of storage click disk management . You should see you 2nd hard drive (labelled disk 1 at the bottom) make sure its your 2nd HDD ( Look at capacity in properties by clicking right on it) .Click right on the 2nd hard drive and select format press ok when the new window comes up and its finished.
Posted on Dec 09, 2007
My seagate free agent 320gb hard drive won't power on
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 19, 2012 | Seagate FreeAgent Pro Desktop - 320GB -...
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
Seagate-free-agent-external-drive 320gb doesn`t show up
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Aug 31, 2011 | Seagate FreeAgent Pro Desktop - 320GB -...
I have a Dell Dimension E520 running Windows XP. I have a Seagate Barracuda 7200.7 100 gb Ultra ATA hard drive (model number ST3100011A) with IDE connections (taken from an old Emachines). The plan was...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Computers & Internet
Is a 320gb HD compatible with the Inspiron Dell laptop?
Hi, I think its compatible with Dell Inspiron as long as the 320GB uses the same cable like IDE or SATA with that dell inspiron, and I think if ever your machine right now uses on the IDE cable it can still handel a 320GB capacity because an IDE cable can accomodate up to 500GB size Harddrive. Also I would suggest that if this would work on your machine try partioning your 320GB to one 60GB for your operating system and the other space is for your data storage. Hope this helps
Jun 03, 2010 | Dell Inspiron 6000 Notebook
Western Digital External hard drive not appearing under my computer or anywere else apart from Device manager (USB mass storage device) and safely remove usb hardware, have tried another comp with no luck...
1st dismantle the hdd and change sata to usb adapter. Get cheap on ebay. Certainly, most wd makes hdd motherboard with usb straight away, but still worth to try. BUT, before all check if your pc usb is working, check with mouse or smth. If so, then try change cable. After cable try dismantle that hdd and change mentioned adapter. If none of these work, you then have a lesson, never western digital, seagate only1
Feb 18, 2018 | Western Digital Passport 320GB External...
Adding old hard drive to new pc!
the seagate HHD (secondary drive) need to be on the same cable as the primary HHD. unless you haev SATA. then it is need to be connected to the second SATA connector on the mother board.
go to BIOS setup and make sure the BIOS know there are 2 HHD.
you should be good to go.
Mar 09, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Computers & Internet Logo
142 people viewed this question
Alun Cox
David Payne
David Payne
