Question about Nikon COOLPIX S710 Digital Camera
Hi, my Nikon S710 is frozen in picture playback mode. A picture is displayed on the screen but the camera is completely unresponsive. Thanks
My Nikon D50 in picture play back mode is giving pictures in multi colour not as pictures ?
I'm not sure what you mean by "multi-colour mode" but this page shows all of the possible playback display modes and describes them. Hopefully this helps you. I use a D7000 which is quite similar and I've never seen a multi-color mode. Nikon D50 SLR Review
Mar 23, 2014 | Nikon Cameras
Nikon Coolpix S2500 - How do you see how much memory is available after taking photo's
In the shooting and playback modes, if you're in still mode (not video) then in the lower right corner of the screen is a number in square brackets []. This number is a rough estimate of the number of additional pictures you can take before the card fills up. If the card can hold 10,000 or more additional pictures this number will be 9999. In video mode this displays an estimate of the number of additional minutes of video the card can hold.
Mar 16, 2012 | Nikon COOLPIX Cameras
Nikon Coolpix P100 how to get full screen playback - now has picture on top and odd graph at bottom
While viewing the picture, press the DISP button to cycle through the available views of the picture.
Dec 14, 2011 | Nikon COOLPIX P100 Digital Camera
My nikon coolpix s710 is frozen. none of the buttons work and it is still switched on. how can i get it to switch off and then re-start normally?? please help!!
Hi, There is IC defective part on your circuit board and need fixed it at repair shop. To turn off your camera , just remove the battery
Jan 27, 2011 | Nikon COOLPIX S710 Digital Camera
How do I transfer pictures on the internal memory to the card?
Press the Playback button (right-pointing triangle) to get into the Playback mode. Press the MENU button to display the Playback menu. Scroll down to "Copy."
Dec 15, 2010 | Nikon Coolpix S3000 Digital Camera
My Nikon Coolpix s4 shows no picture on screen but just black. No image.
I wish I could solve as I have the same problem. The LCD shows the menus settings but does no display the picture image - same whether in camera mode or playback mode. Please help.
echorey@hotmail.com
Oct 14, 2010 | Nikon Coolpix S4 Digital Camera
How do i set my camera to date the pics?
Display the playback-mode or shooting-mode selection menu by pressing MODE. Use the rotary multiselector to select the wrench and press OK. Use the rotary multiselector to select "Date Imprint."
Jul 26, 2010 | Nikon COOLPIX S710 Digital Camera
Nikon s710 pictures captured look yellow and darker than usual
Can the white balance have been changed accidently?
This will make the pictures look yellow.
So will taking pictures indoors under artificial light.
The White Balance setting is under the shooting menu, try setting it to auto.
Hope this helps.
Feb 25, 2010 | Nikon COOLPIX S710 Digital Camera
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
Mar 30, 2009 | Nikon D60 Digital Camera
Nikon COOLPIX S710 Digital Camera Logo
255 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
