TOSHIBA 35a44 Chassis no. TAC 426. The TV volume started to go to 0 all by it self. When this happens the function stays active as if I'm commanding ''Volume Down'' ,(Remote or panel buttons),and no other functions are allowed. From time to time it will stop commanding volume down and will allow you to turn the volume up and as soon as you release the command the volume returns to 0 by itself, also the TV eventually stopped doing this for a couple of weeks. All was fine, then back to this problem and then it wouldn't turn on at all. After having it unplugged for awhile and looking at the board looking for burnt components, bad solder joints, and visually obvious problems, the TV now turns back on and I am back to my original problem.
  • chritcher Sep 08, 2009
    THE REMOTE IS NOT THE ISSUE. I USE THE DISH REMOTE AND THE TV REMOTE. I REMOVED THE BATTERIES FROM THE REMOTES AND THE TV ACTS THE SAME. OHMED FRONT PANEL SWITCHES ALL WORK CORRECT.
    Novelist:
  • 133 Answers
Try to check the pannel and the remote "volume down" buttons - one of them could be stuck in a pressed position.
It usually happens on the remote when dirt or sticky substances accumulate around the rubber buttons - you need to disassemble the remote and clean the rubber pad and the remote housing with some ethyl alcohol and cottonwool, also clean well the holes on the housing where the buttons protrude.
If you also decide to clean the contact tabs on the rubber pad and the circuit board, you should clean them gently to avoid damaging the conductive coating.
I hope this helps somewhat.
regards
3rq8 (Triarcuate)
Posted on Sep 08, 2009
  • 4L60B4R1UM Sep 08, 2009
    regards
    3rq8 (Triarcuate)
    Next things i would have checked:
    - remote sensor pins on the TV, any connectors or wires going from there to the main board, the sensor decoder IC and the associated components (power supply electrolytic capacitors, resistors, diodes, etc) - a detailed schematic would be very helpful here
    - TV's audio amp section and amp control section, any connectors around there, power supply capacitors in the audio section (possibly also capacitors in the main power supply) - again, a schematic will save you a lot of time.
    Bad electrolytic filter capacitors in any section will often cause power supply disturbances that may result in a malfunction or erratic behaviour of that section of the TV set.
    If any capacitors are bulged / blown at the top, they need to be replaced.
    There may also be dried out filter capacitors which don't show external damage - these would require scope metering and / or voltage measuring, or you can parallel them with good ones (yes, one by one, until you eventually find the one that is bad - assuming there is one).
    That's about all i can suggest, maybe try to see if there is any change when you disconnect the dish unit from your TV (a bit unlikely but you can try it).
    Thanks for your comment
    regards
    3rq8 (Triarcuate)
Toshiba 35a44 Tv keeps going to demo mode
let the card be cleaned with sprit, some contacts are still holding down.
that will solve your problem
Nov 12, 2008 | Toshiba 35A44 35" TV
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Remote not functioning, t.v. scrolling menu on its own?
Tv is in DEMO MODE...consult owners manual for activate and
de-activate instructions ......................................T.
Dec 11, 2007 | Toshiba 35A44 35" TV
TOSHIBA 35 TV 35A44
don`t know if this will work for yours but I have heard of menu coming up all by itself randomly and the fix was to remove the batteries from the cable boxes remote and the tv`s remote, partially stuck on buttons were the cause, replaced the remote end of problem, hope this helps on yours.
Nov 29, 2007 | Toshiba 35A44 35" TV
Toshiba 35
turn the tv off ,disconnect from power source , then you can
wait 1 hour appx. ,for the crt to discharge it self ,or you can
being very  carefull discharge the crt by inserting a long
screw driver under the ground strap that runs across the crt
(thats the metallic one ) the other screw driver under the anode
high voltage cap (thats the one that connects to the top center
of the crt) then short the two screw drivers together ,you should
see a little spark if there was any voltage there ,after that you
can solder  all the cold solder joints.
May I suggest that you check the main chassis also for cold solder joints.
I have checked many a TV.,and I always check the main chassis  to prevent callbacks.
BE SURE  NOT TO CREATE SHORTS WHEN YOU SOLDER
USE A 40 WATT SOLDERING PENSIL/IRON
TAKE YOUR TIME. YOU SHOULD HAVE NO PROBLEM.
Oct 23, 2007 | Toshiba 35A44 35" TV
Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
Aug 23, 2007 | Toshiba 35A44 35" TV
Volume Issues with Television
toshiba 35a44 I had in shop would not turn on initially,when Qa01 was replaced I was able to turn tv on, but after a couple of minutes volume went all the way down, vol display bar on screen and power and menu keys would not work, remote control function did not mater. after replacement of QA02 mpu no results. desoldered volume down and up keys and sprayed chassis with flux remover on both sides of chassis and sumerged vol keys in alcohol solutions for 10 minutes, restored them in chassis and the problem was corrected. QA01 and QA02 did not had to be replaced there was a contaminant problem on solder flux that was causing the problem. kbzon
May 11, 2007 | Toshiba 35A44 35" TV
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
Electro Med Services...
