Question about Panasonic CT-32SX12 32" TV
TV won't turn on
Same as described by other people, TV worked fine, turned it off, now it acts like it is getting no power.
  • 80 Answers
Take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Posted on Sep 07, 2009
Samsung 13 tv can't get it to run what can I do?
As you and I don't know what the problem is, certain basics have to be first covered. Here is a link describing basics for any TV.
TV Power Light Comes On But No Picture Or Sound
As I don't know if you have an active led power light, here are a couple of videos:
EASY HOW TO FIX SAMSUNG TV NO POWER
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
Samsung TV Won Turn On Has No Power No Standby Light Samsung LCD TV...
If the set is powered up, you can try resetting it to factory defaults. Yes, any of these suggestions may not work but one of them might fix your problem. You might try searching for tips by including the model number in the search. Bear in mind you are dealing with a high voltage device and your next repair may be at the hospital if you are not exceptionally careful.
Feb 28, 2018 | Samsung Televison & Video
Old GE 27GT615 TV won't power on
Could be an open internal fuse or power supply failure
Dec 19, 2017 | GE Televison & Video
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Samsung LN-S4695D LCD WON'T TURN ON BUT POWER LIGHT IS ON ?
I would recommend you get a professional diagnosis. There is high voltage present in the set that can harm you. Being that you never messed with a TV, you could possibly cause more damage to your set. These flat panel TV contain sensitive circuitry. What you are describing sound like a fault with either the power supply or main board.
Dec 01, 2012 | Samsung LN-S4695D 46 in. LCD HDTV
I own a 2001 jeep cherokee laredo. when i start off it will shut off while driving, but starts right backup will do this two or three times then runs fine after that. acts like it stops getting power all...
Chrysler products are notorious for the crankshaft sensor going out and causing the symptoms you are describing. It also won't set a code to turn the check engine light on.
Jun 02, 2011 | 2001 Jeep Grand Cherokee
I have a polaroid lcd tv model FLM-373B. Screen is black when the tv light is blue and cannot get tv to respond to remote. I try to use the controls on the tv it will not respond to turning off unless...
by what you describe it could be a power supply board that is acting up, Parts are available through different on line parts stores, or the board can be repaired, but first you'll need to get a technician to verify that the defective board is the power board.
Jan 09, 2010 | Televison & Video
Hitachi 50UX58K-V8F001238
our hitachi did the same thing. It cost us 300.00 to tell us that there were two bad solder joints and they caused a power surge or something.
Apr 17, 2008 | Hitachi 50UX58K 50" Rear Projection...
Panasonic CT-32SX12 32" TV Logo
406 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
