Question about Lands Phones
Replace the screen
Hi, I need to replace the screen and can not find any one in my area that knows this phone.
I need the repair manual
  • 99 Answers
Most cases if the phone is from another country, the parts are not supported here in the U.S .. however what's the model number of the phone and type maybe i can direct you to a local shop that may have what your looking for
Posted on Sep 07, 2009
Razor v 3 keypad will not light up,everything else is fine
Hi,keypad light issues for Motorola phones are usually caused by the flex of the phone and also the Keypad IC.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
also When buttons on a cell phone does not work , it is usually a problem from the Board of the cell phone. An IC problem...
IC are small chips that has different functions on the cell phone. Each IC chips on the cell phone has it's function. The IC controlling the function of the keypads npt working is damaged and needs to be replaced.with another IC chips.
You can get IC chips from your mobile company mini office or you can simply go to the nearest Expert repair store around you area to replace the damaged IC chip that controls the key pad not working.
Sometimes, it might just be dirt or water spill that is making it not to function. You can open the cell phone and clean the keypad area,
Hope it helps.
Thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
It has lost display
Hi, display lost is classified in different areas:
When a phone has VIRUS in it, it might make the screen go white, through downloads from the internet or from another cell phone through data cable transfer or blue tooth.
Solution: Needs to be flashed.
Also when there is screen damage.it can make the screen go white. You will know if it is the screen when you switch on the cell phone and you can still operate the phone with out seeing anything.
Solution: you will need to replace the screen.
You can use the link below to replace the screen .
formymobile.co.uk/6700disassembly.php
And also when a phone drops on the phone, and the screen shifts from it's position,that can also cause white display on cell phone.
You can use the above link to use and check for screen shift...
Hope it helps.
Take care...
Mar 11, 2011 | Nokia 6700 Classic Cell Phone
My sreen is showing upside down how can i fix this problem?
HI, when a screen starts showing upside down display,that means the flex of the phone is getting damaged.
The flex is a thread like object that connect the phone board to the screen display area.
The flex of the phone allows the phone to display of the phone.
To be able to correct the display problem,you will need to replace the flex of the phone.
Phone is a little bit technical to handle,i would advice you contact a skilled phone repair manin any phone repair store around your area for assistance..
Hope that helped.
Jan 21, 2011 | LG Rumor 2 Cell Phone
The screen of my motorolla cell is broken because of dropping down .can it be repaired
Hi, it can be repaired. Just take it to any phone repair store around you area and take will replace with a new screen.And it does not cost much.
Take care.
Aug 07, 2010 | Motorola Cell Phones
Samsung s5200 phone ring but screan is blank
Hi,from your question,two things might be the problem,it's either the phone's flex is bad or the phone's screen is bad,which needs replacement or repair
Here is the solution,
1,Put off the phone and remove the battery for at least 6hrs.
2.After 6hrs,replace the battery in its space behind the phone and turn on the phone.
3.The screen ought to come on after step 1 and 2
However,this might only be a temporary solution,but the permanent solution is;
Consult the nearest qualified phone technician in your area to help you fix either the flex or the screen.
Note;Please don't try fixing it yourself if you don't have the skill and technical know-how because this might compound the problem of your phone.
Take care
Mar 11, 2010 | Samsung SGH-U700 Cellular Phone
Screen
Hi
Warranty wont cover a cracked screen since its not a manufacturing fault its "abuse" (droping the phone etc)
You will have to pay nokia to replace / repair the phone. You can possibly order a replacement screen from ebay for example and replace the screen yourself or get a local repairer to replace the screen for you.
Let me know if you need further assistance.
Thanks,
Ekse
Aug 14, 2009 | Nokia E71 Smartphone
How do I replace the LCD screen on my i885 cell phone?
Do can get fixed in a local cell repair center or can find parts on e-bay, and get it it fitted manually
Apr 25, 2008 | Cell Phones
Fix cracked iphone screen
HI
If you have part then I can fix it for you. Labor cost is $85.00. Please email me at joe_dao2003@yahoo.com for more information.
Regards,
pingping
Mar 02, 2008 | Samsung SGH-D900 Cellular Phone
PHONE REPAIR
i don't know exactly but let me tell you that u can change ur lcd by urself. just open the cell phone disconect the lcd conector and replace the newone
hope you ll change it
Dec 08, 2007 | Cell Phones
LG Shine
So do we have to break the glass manually? or is there a spcial way to remove the glass to replace it?
Aug 19, 2007 | LG Shine KE970 Cellular Phone
Lands Phones Logo
19 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
