Question about Panasonic KX-P Laser Printer
I have an old Panasonic KX-P4410 laser printer that I just love, but it is displaying an error code E31 - the halogen heating lamp. Where can I get one??
I have one you can have.
Posted on Feb 15, 2010
Error messgae
sir i have panasonic fax KX-MB2030 call servic 3 error i try #900* 550 but it is not work
Nov 28, 2013 | Panasonic KX-FL611 Plain Paper Laser Fax
Getting an E31 message on my KX-P4440 printer... what does it mean
It means "heater quartz lamp" problem and must be replaced. It's going to be hard because it pretty old.
pls. vote for better service. Thanks
Nov 12, 2010 | Panasonic KX-P4440 Laser Printer
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
PHASER 8200N ERROR CODE 15,004.45:7829
There are 2,,,, 150 watt halogen lamps in that machine that heat the drum. One or both have blown. How to be sure is, turn the lights off in the room of office the machine is in, turn the machine on, and look into the right side fan slots. After a minute or 2 you should see a glow inside the machine. ( You won't) those lamps are bad. Xerox will want to sell you a new drum heater for over $200,You can go anywhere that sells halogen lamps. Lowes, Home Depot or just about any place that carries lamps will have them. They are less than $15. I recommend , if you can find , the Sylvania lamps that are rated for 130 volts and are vibration protected.
If you want to try and replace them. let me know I will send you written instructions. Should take an hour or so to replace.
Mar 10, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Please help. error report, 15,004.45:54183
There is a set of 2 Halogen lamps in the machine that heat up the drum. They are 150 watt halogens, one or both have burned out.
The way you determine it is turn the lights out in the room the machine is in and then turn on the printer. Look on the right side of the printer, there is an exaust fan vent there. Look inside for lamps glowing, I very seriously doubt they will be glowing. If not the lamps are bad, When one goes out neither will work.
If you want to attempt replacing those, let me know I can forward you some instructions.
Nov 18, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Failure to print
Hy i had the same error message the error comes from the fuser unit , the halogen lamp is not heating , on the top of the fuser unit is a Thermostat in series with the halogen lamp wich u have to replace. Its not that easy if you dont have experince but it will solve the heat error. I hope this helped
May 21, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Call for service E31 in oanasonic printer KX-&4400
Sir,
Please help in installing my printer. Below given is the printer information.
machine type 4523 ca ices-003 . need softtware to start my printer ASAP .
Look forward to you earliest reply.
Thanks & regards,
kaccounting@gmail.com
9058220838
Apr 26, 2008 | Panasonic KX-P4420 Laser Printer
Panasonic KX-P Laser Printer Logo
399 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
