Question about HP Pavilion a767c (82916052406) PC Desktop
It be easier to replace a lcd monitor or fix it
  • 3,153 Answers
Drallim is correct and EBAY is your best friend not only for the replacement screen but many of the sellers can supply instructions to do this.
if you are carefull it is not a difficult thing to do.
Just remember to remove the battery and poer source first
Posted on Sep 07, 2009
    Brigadier General:
  • 4,088 Answers
It would probably be cheaper to replace than to repair. I would guess $100+ to repair, and the new ones seem to be getting better all the time.
Right side, settings buttons !
your side button are get dusted and short may b so open this Cover of LCD and replace those buttons.
Sep 14, 2012 | Samsung SyncMaster T200 LCD Monitor
My screen is totally black and will not turn on the computer but the green light is on???
Most likely a screen problem. Are you able to try another monitor with your PC? If a different monitor works, then the problem is your monitor. Most LCD monitors have a rather short life span (well, much shorter than the heavy old CRT monitors). But whichever kind of monitor you have, it seems to be getting power but is unable to display an image.
If your monitor is an LCD monitor, then the problem could be the backlight. If you take it to a computer repair shop, they should be able to replace the backlight - if it's cost effective to do so. Without knowing more about your monitor it's difficult to judge what the best solution might be. Sometimes it's cheaper and easier to get a second hand screen from Ebay rather than fix an obsolete LCD screen. On the other hand, if you bought the monitor within the last 12 months and spent a lot of money on it, it may well be worth getting it fixed.
Oct 10, 2010 | Computers & Internet
I have a Dell e173pfb monitor. i push the power button and green light comes on screen comes on for a second with no problem then the backlight goes off. I can still see an image with a flashlight though....
You need a new backlight inverter board. If you dissasemble the monitor you will see a circuit board with 4 2-wire connectors connected to it. This is the board you need to replace. Typically they run from $15 to $40. Usually just easier to replace the monitor. Another idea is to reduce brightness levels on the monitor in the menu while looking at it with your flashlight. Then power off then power on the monitor and it might stay on longer.
Aug 16, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Hi my pc monitor keeps turning off & on, why and how do i fix it???
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | Princeton Digital VL1916 19" LCD Monitor
LED POWER ONLY LIFE, SCREEN DISPLAY DARKNESS
theres only one solution to the problem you have to replace the whole power supply board .its easier to replace them than finding and soldiering the defective parts like the capacitor on the board .u can just replace the power supply board if u think the power has a problem. if it doesnt work then u have to replace also the main board or the board connecting the rgb cable.its more expensive to replace the board but its worth it. ur lcd will work better and its easy to put them on the lcd casing .
Mar 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Desktop icons appear as a shadow on all windows.
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Sep 29, 2008 | Acer AL1714 17" LCD Monitor
Bruises on lcd monitor
may be u ve to change the screen of ur LCD
Feb 17, 2008 | ViewSonic VX2255 Monitor
Backlight replacement
Are you sure it's the backlight? Many Planar LCD monitors have issues with the capacitors on their power supply boards. The symptoms include a power light and no picture, or just a flash of a picture when powering up and then nothing.
The fix for some of these problems is about $8 on new capacitors (Plus shipping).
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3/4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work if the failure looks like I described. I've fixed several of these monitors so far. All the problems were related to the power supplies. Same with the Planar PL1700 LCD monitors.
Jan 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
LG L1930B 19" LCD Monitor Problem... HELP
When an LCD Monitor starts to respond like this it is due to one of three reasons a power supply is not generating enough power to properly power the LCD or the LCD's backlight is beginning to burnout, and last the inverter is bad. These things all can be replaced, but it is not worth the cost! Easier and cheaper to buy a new one!
Nov 25, 2007 | LG L1930B 19" LCD Monitor
Replace Monitor Speaker
too much hassle, just buy a pair of seperate speakers for your desk, it'll be much easier
or if the monitor is within warranty, enquire with your supplier about a warranty repair/replacement
Oct 15, 2007 | HP Compaq FP5315 15" LCD Monitor
HP Pavilion a767c (82916052406) PC Desktop Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
