Question about Canon PIXMA MP190 All-In-One InkJet Printer
Can't load printer ink cartridges...
We can not get the cartridges in place. We've followed the directions on the sheet and nothing works. Any suggestions? My son has to print a report for school tonight.
    President:
  • 566 Answers
Are you using the right cartridges? They should be:
  • PG-40 BLACK (Black Ink Tank)
  • CL-41 Color (Color Ink Tank)
Also check this CANON FAQ:
How do I install the ink cartridge(s)?
Posted on Sep 08, 2009
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
I was given an HP Officejet J3640. I installed the HP21/22 ink cartridges, printed the alignment page, then loaded the alignment sheet in the feeder. After I loaded the alignment sheet, it responds...
Hi
Check if the alignment page has been printed correctly i mean the bars printed with a little yellow color around it right?
Okay what you can do is do a reset first. Follow the below things
1. When the printer is on remove the power directly from the back of the printer.
2. hold # and 9 key and connect the power
3. Printer will show you on the screen it is resetting the NVRAM then release the buttons
The printer will print alignment page again this time try to scan and it should work.
DO RATE MY SOLUTION
Jun 30, 2011 | Office Equipment & Supplies
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
Cant load the printer cartridges for the pixma mp190
If you are trying to figure out how to load your ink cartridge in you Canon Pixma follow these instructions.
Make sure you printer is powered on. Open the top cover including the key display.
  • Step 2 Allow the ink return to move to left and stop. Remove the old cartridge which should have a 40 Black or 40 color on it by pushing down and popping it out of the holder.
  • Step 3 Now open your new ink cartridge and tear off the protective stip from the ink cartridge.
  • Step 4 Place the new ink cartridge in at a downward angle and then push into a straight position by pushing the bottom into place.
  • Step 5 Close the top an allow for the printer to adjust into place. Do a test print to make sure the printer is working correctly.
  • Step 6 If you experience an error message refer to your canon guide book for troubleshooting tips. Be sure your new ink cartridge in placed in correctly. Should be next to the other ink cartridge in same alignment.
  • Mar 22, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
    Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
    U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
    Install the proper ink cartridge.
    Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
    If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
    Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
    Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
    By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
    Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
    - images edited on the computer
    - images in a format other than JPEG or TIFF
    - images with double-byte characters used in the file name
    - images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
    Disconnect the cable between the printer and the camera to clear the error.
    Confirm the following items and print again.
    If the camera does not support either one, the printer cannot print directly from the camera.
    Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
    Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
    Press the OK button to clear the error.
    Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
    The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
    About ten minutes later, plug it in again, and turn the printer on.
    If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
    Press the OK button to release the error.
    Check the followings and do automatic print head alignment again.
    - Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
    - Check if the paper output slot is not exposed to a strong light source
    - Print the nozzle check pattern to check the status of the print head.
    If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
    1. Confirm that unusable paper is not set.
    2. Confirm that paper is set properly.
    3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
    4. Cleaning the paper feed roller may resolve the error.
    If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
    If paper jam frequently occurs, check the following:
    1. Confirm that no foreign material is inside the printer.
    2. Confirm that unusable paper is not set.
    3. Confirm that paper is set properly.
    4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
    Dec 27, 2009 | Canon Office Equipment & Supplies
    Error Message U053
    Error messages displayed on the LCD and how to handle them
    When an error has occurred in the printer, the error / check message is displayed on the LCD.
    Take the appropriate action to return to the normal condition.
    Error / Check message How to correct CHECK INK
    U041 An ink cartridge is empty.
    To cancel printing, press the Stop/Reset button.
    To continue printing, press the OK button.
    After the printing finishes, replace the empty ink cartridge.
    Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
    Red light on steady
    If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
    If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
    May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
    Epson d78 printer
    Usually the new cartridges come taped at places where the
    ink is supposed to come out of, for shipping purposes.
    Before installing you should have removed all those
    tapes. There may be in more than one place per
    cartridge too. Your little cartridge instruction booklet
    should show you where they are and how to remove them
    From what you are saying I suspect you did not
    remove those prior to installing?
    I am getting mine from
    http://www.inkfilling.com
    and they come with instructions as above.
    If you did remove them then you may have not
    installed the cartridges correctly perhaps did not
    place them completely in their socket.
    If you did then you must have something clogged
    possibly printhead but i doubt that, most likely to be
    one of the above.
    May 01, 2009 | Epson Computers & Internet
    Canon PIXMA MP190 All-In-One InkJet Printer Logo
    133 people viewed this question
    old marine
    old marine
