Question about Jensen TS2050J 20" TV
I have a Jensen HDTV, model number JE3207. I lost the remote and it won't search for channels because I don't have a way of entering the passcode. I've tried a GE Universal remote but it doesn't respond, any suggestions? Please help!!!
  • 163 Answers
SOURCE: Universal remote
the universal remotes work fine in any tv, but limited to basic funcion, if you whant full funcion one, go to, www.remotes.com or call 1-800-remotes..good luck
Posted on Aug 10, 2006
SOURCE: Using a Jensen remote, can't access input mode
turn on your tv, press and hold tv button, then the on/off button, it will light up then press the power button.and it turns off....hold. After holding down both for buttons for 3 secs the light on the on/off key turns back on. Release both keys and the light should stay on. Now hit the On/off button repeatedly until the tv turns off, when it does hit the stop button to save code.
Posted on May 05, 2007
SOURCE: what universal remote that will work on jensen TS2050J TV
remote model UNIVERSAL dt008 use code 044
Posted on Sep 08, 2007
SOURCE: Programming a Jensen JER 422 universal remote to a Sanyo Television
To Sarah,
In order to program your TV:
1. Manually turn on your component.
2. Press and hold the component key you wish to program, in your case the TV key.
3. While holding down the component key press the four-digit code using the number keys (0-9) to enter it.
4. After the fourth number is entered, the illuminated ON-OFF key turns on. At this time, release the comonent key. If the illuminated ON-OFF key turns off, you have entered a valid code.
NOTE: For Sanyo TV it could be any of the 8 next codes:
1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
Good Luck !
Carlos Vallejo
Posted on Jan 03, 2008
josh1856
  • 105 Answers
SOURCE: Jensen JER321 3-Device Universal Remote
coding:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Posted on Jan 26, 2008
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Televison & Video
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How do i disable the child lock
Sep 18, 2012 | Jensen TS2750J TV
Tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 | Televison & Video
Tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
Tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
Tip
Bypass Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
I hope that helps.
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Televison & Video
Tip
Reset Mitsubishi HDTV VChip Password
I hope that helps.
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
I hope that helps.
Jensen TS2050J 20" TV Logo
64 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
