Question about Dell Dimension™ B110 PC Desktop
I have a dell b110 dimension...i took the memory out to see what kind of ram it was to add more to the system. When i replaced the ram, it wont boot up. when you push the power button, it hums like it is trying to start, then clicks and the power indicator turns amber, sits there and will not boot. any ideas?
    Scholar:
  • 106 Answers
First off, You can't just add memory to any Desktop or Laptop, most computers have a set amount that can be installed especially if Your still running Windows XP with a Celeron Processor so the most You could possibly add is 1 Gig by removing the 512MB and if it has 2 slots then most likely the most you can put on are @ 512MB sticks. I know this cuz I have a Dell Optiplex which won't allow me to add more than 512 in other words 2 286MB sticks. Hope this Helps, Good Luck =)
Posted on Oct 18, 2011
  • 448 Answers
The Computer is shipped with DDR-SDRAM 333 or 400 MHz RAM module.
Make sure that you're using a compatible RAM module.
You may try reseating the RAM module in the memory slot.
Take out the RAM module then clean the RAM slot then reinstall the module. Ensure that the RAM module is properly seated into the slot. Furthermore, ensure that the newly installed RAM module's capacity doesn't exceed the supported capacity.
If the issue persists then you may try installing another compatible RAM module.
Posted on Sep 07, 2009
    President:
  • 2,187 Answers
Check first if the memory is loose or there are any parts that have come loose such us IDE or SATA cables, For errors you should also get warning sounds.
I added memory to my dell b110 desktop and now the tower wont power on
The memory you have added is not compatible sounds like you have installed 266MHz memory when you need either 333MHz or 400MHz cheers from Scott
Dec 28, 2010 | Dell Dimension™ B110 PC Desktop
When I push the power button on my Dell Dimension B110, nothing happens. There is power to the board, as there displays a green light. What shall I do?
take a look inside ..maybe wires are loose or something like that .. and while you are doing that ..remove the ram memory also ..and check them one by one ..and see if it boot-up or not ..also remove the bios battery and place it back ..If by mistake you selected something in bios related with the power button or the way it will boot up ..this will default the bios and will get it back to the factory settings ..and it may work if it is something related with it ..
Otherwise..I can not see what the issue may be ..but a faulty motherboard..or something related with the cpu ..try to see if the fan is working ..If this is unplugged or malfunctioning ..it will cause the cpu to stop the boot up ..
Oct 22, 2010 | Dell Dimension B110 PC Desktop
My parents have a Dell Dimension B110 computer and they were going to install some new RAM. They took the old ram out, realized they bought the wrong kind, put the old ram back in and now the computer...
Make sure the ram is installed correctly. You didnt break it when you put it back in did you ...
If you get it going again... please go to www.4allmenmory.com and have them scan your computer. Review their results and recommendations
Im sorry their computer isnt working.
Thanks for using fixya.com
a
Oct 26, 2009 | Computers & Internet
How to add extra memory card in the mother board
well u may upgarde your ram to 1 or 1.5 GB if less ... and try installing Windows 7 on your computer i can tell you how to download or if you already have ... then the speed will not bother you any more...
Jun 23, 2009 | Dell Dimension™ B110 PC Desktop
Memory Upgrade Attempt Causes Computer Not to Post
Seeing as the message is indicating a problem at one of the timer checkpoints, fatal is probably an accurate description. You are most likely looking at a motherboard replacement scenario. I've seen improperly seated memory modules toast timer circuitry on old boards back in the days when most of the timing circuitry was constructed from discrete components, not entirely IC-based timing solutions, but I have never seen it happen on modern boards.
Apr 10, 2009 | Dell Dimension™ B110 PC Desktop
Dell b110 won't boot
The diagnostic codes you mentioned A & B amber C & D green indicate that the issue is related to the memory. Reseating the memory firmly resolves this issue. Most times the memory needs to be firmly pressed in till the latches click.
Below is the link to the No Power, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=false
Follow all the steps and if there is no hardware failure, this will definitely resolve your issue.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 25, 2009 | Dell Dimension™ B110 PC Desktop
Cant get My dell Dimension b110 to boot no display on moniter!
Which Ram u r using ( DDR, DDR2) , and whats the make of u r PC, as per my understanding Ram is not compatible, is old RAM is still working.
Nov 01, 2008 | Dell Dimension™ B110 PC Desktop
Mainboard not reconizing my hdd
check to see if your ram has not losse, had the same problem with a mates computer.
Jul 03, 2008 | Dell Dimension B110 PC Desktop
Dell will not start
You need to open the case and locate the memory....
Remove it and clean the contact point with a pencil eraser...
Place it back and turn it on...
How was it... Fixya right.
Feb 05, 2008 | Dell Dimension™ B110 PC Desktop
Dell Dimension™ B110 PC Desktop Logo
279 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
