Question about Air Tools & Compressors
Cannot get Wagner paint spayer model 834 cw15 to get prime? Bought unit used so do not have users manual?
  • 62 Answers
There is a check valve..or ball and spring inside unit that is clogged with old paint. Dissasemble the unit to repair..but make sure you can get parts first.:)
Posted on Sep 08, 2009
My Wagner Xtra Painetr Pro will not spray paint like it is not drawing paint and it was never used. Do you put oil in it somewhere? It is like it will not get primed.
no. tell me more are you using cup or paint hose? if using cup perhaps your paint is too thick, try adding flotrol to pain and mix
Oct 29, 2017 | Wagner Air Tools & Compressors
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
Wagner paint crew model 770
It doesn't take much residual paint to dry out in hose and block it.Have you lowered the paint pressure?
Wagner 770 Owner Manual Page 8
Nov 27, 2017 | Air Tools & Compressors
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
Have a Wagner Paint Crew and it started out fine and then after a half hour or so, it gradually lost pressure to a small stream, I was using new paint and I cleaned the hose, screean, intake valve, and...
hello ald... use a fine piece of wire and clean the opening that the paint comes out through. It has a tendency to fill in as you spray. Joe
Jun 28, 2011 | Wagner Plumbing
I have a Wagner 834cw15. Spraying fine 10 mins ago. Now...can't get it to prime. Any suggestions? Spraying oil based kilz
http://www.wagnerspraytech.com/portal/loader.php
I cannot find model 834
Check your owner's manual for troubleshooting steps
We used paint sprayers every day for years.
The prime valve goes bad
The steel balls that direct the paint between prime and hose, wear out
The steel ball that holds prime and hose pressure wears out
The steel balls can also get stuck
Turn prime lever on
Take a hammer and tap/bang front of paint sprayer until ball comes loose
I cannot see your sprayer so I don't know where the ball is located
The photo below says, keep lever up >> in your case lever is down or in prime position while tapping
To post a photo of your paint sprayer so I can see it:
Read:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answersAnd then add comment at page bottom and it sends me an e-mail
I will be here for another 45 minutes. Its 526 cst
Oct 26, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
318 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
