Question about Marshall Music
My marshall jcm2000 dsl50 will not power itself the mains lead is fine and none of the fuses are blown but it wont power i have only had it four months why is it doing this.
  • 70 Answers
Check standby power supply,it stays on all the time main power is off and is subject to damage from transits from power company.Bad switch?
Posted on Sep 07, 2009
No power in marshall woburn
Mains fuse blown perhaps
Jan 30, 2017 | Marshall Music
Changing preamp tubes in marshall dsl50 50 where
The bias voltage goes to the output tubes only. These go into the larger tube sockets.
Oct 05, 2014 | Music
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
Sep 04, 2014 | Marshall Amplification Music
My Marshall 250dfx has stopped working, there is power but nothing is coming out. No crackiling before, one min it was fine, the next it stopped.. Help!!
try another speaker or test the speakers on another amp. if the speakers are working then it's your amp . check out the output ic's. they maybe blown.
Dec 03, 2013 | Marshall Amplification Marshall MG30FX...
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Have marshall mg100 hdfx head -power it up and blows fuses right away!
This is either a shorted component in the power supply section or in the power amp electronics itself. Continuing to replace a fuse MAY damage additional components. Take unit in for servicing.
Nov 29, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
Feb 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Yesterday, I accidentally switched off the powerstrip which my 100 Watt JCM2000 DSL is plugged into. I immediately turned it back on, without shutting off the power, and heard a "POP" I then tested the...
It is unlikely that your actions with the plug strip caused any permanent damage to your unit.
If you unit has a digital effects unit, probably the setting for that got disturbed and you need to reset it to your desired setting.
Jan 18, 2010 | Marshall Amplification Music
Hi im in Argentina and i accidentally pluged in my amp without an adapter now it doesnt work what needs to be fixd?
The power supply is blown. Argentina is 220V I believe. I have never seen a power supply schematic for this however being that it is low power it is a linear supply not switching. Either the rectifier diodes are blown out or possibly the output capacitors are blow due to approx double voltage. If you try this yourself be careful otherwise get a new amp. Good Luck
Dec 14, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Music Logo
82 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
