Elimination Of Problems From Most To Least Likely:
I know you said the drain's not blocked, but i feel obligated to mention it anyways ;)
1. Connection from discharge hose to drain pipe is blocked/corroded. a) Loosen the gear clamp (5/16" Nut Driver/Phillips/Standard) holding the discharge hose to the barbed drain fitting. b) Check that the barbed fitting is not blocked by poking at the opening wth a screwdriver. c) If the barbed connection is Galvanzied and it has gotten heavily corroded, replacement of that fitting is recommended.
2. Discharge hose is blocked/kinked from dishwasher to drain connection. a) After 1b), place discharge end of hose into a bucket and run the dishwasher through a cycle. b) If flow is poor, examine hose for kinking or parts (such as couplings) that may have corroded shut. Removing front panel and using a flashlight will be required for this (1/4" nut driver/phillips) If such corrosion found, 1c). c) If hose and fittings are ok, there may be an inline filter whose screen is clogged or a filter screen where the dishwasher ties into it's discharge line. 3. Pump has failed internally . Usually held in place by large squeeze clamps, screws, gear clamps. Will most likely removal of dishwasher from alcove to repair. Any reputable dealer should stock parts. i.e. Kenmore => Sears N.B. May be under warranty - check. May be cheaper just to get another dishwasher at this point, especially if the dishwasher is more than 10 years old.
GE dishwasher, will not drain completely. Leaves about 1/2 inch above bottom screen. What controls when water pump shuts off? Is there some type of float?
Was this helpful?
Yes
No
Popular Solutions for GE 24 in. GSD6660GSS Built-in
My GE Triton dishwasher does not dispense water at the end of the cycle. Every other cycle is...
(More)
My GE Triton dishwasher does not dispense water at the end of the cycle. Every other cycle is complete except the last one. can you provide some solution why the last cycle does not work?
i have a fridgidair dishwasher. when opening the door it squeeks like like a rusty henge. it does...
(More)
i have a fridgidair dishwasher. when opening the door it squeeks like like a rusty henge. it does the same when i close it. i have lubed everything with white grease but it still does it.
