Question about JVC HX-C6 Shelf System
The protect mode issue
It goes into protect mode and shuts down is there a quick fix? or should i just scrap the unit and go get sony products?
  • 70 Answers
Disconnect and/or turn off speakers and see what happens.Check for running cooling fan and that unit is clean inside and has good ventilation.
Posted on Sep 07, 2009
It goes into protect mode then shuts off. its not the fuse and i have unpluged all speakers and it still goes to protect mode then shuts off.
I had the same issue - I found that there is a square chip, about an inch and a half from the amplifier chips and heat sink, which got so hot (i could not even touch it), it was seperating one of its pins from the circuit board (due to a hairline crack on the pin itself. When it got that hot, ther metal pin seperated at the crack which made this chip short out, creating the "protect" to happen. I resoldered the solder joints on the circuit board where the pins of this chip connected and fixed the cracked pin with a jumper strand of wire, then made an aluminum heat sink and connected it directly to the chip -no more issues!
Nov 25, 2011 | Sony STR-DG510 Receiver
Can't open,in protect mode
Hi:
First disconnect all speakers from the unit and then try turning the unit on too see if it still goes to protect mode. Protect mode is a shut down feature that shuts down the unit because of a shorted speaker or speaker wires are touching each other. If the unit does not shut down after disconnecting all speakers then reconnect them one at a time while turing the unit on after each conncection until you find the shorted speaker. If it shuts down with no speakers attached to it then you have a internal problem with the amplifier section, probably a shorted output transistor in the Amp circuit or preamp circuit.
Jul 08, 2011 | Yamaha Audio Players & Recorders
Ok, so i had a YLOD issue. Went through step by step with the common repair. Stripped it down to individual components, cleaning each as I went. Used the heat gun technique and followed the instructions to...
Hello , there is a thermostat in the unit and quite often when i do the ps3 or xbox reheat and assemble and test too quickly its still too hot on the ic and goes into protect mode.Try it again now that its cooled down.
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
Goes into protect mode and shuts off. Any
If the unit goes into into protection it usually means the amp is blown. It would need to go into a shop for service if the repari is not cost prohibitive
Dec 11, 2009 | JVC HX-C6 Shelf System
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Power turns off
Bad speaker wiring.
Internal fault.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Unit shuts itself off after 10 -15 minutes
Bad speaker wiring.
Internal fault.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Bad speaker wiring.
Internal fault.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Home Theater Audio System System
Bad speaker wiring.
Internal fault.
Regards.
Dec 22, 2008 | Samsung HT-TX72 Theater System
My DVD HT-Q9
Bad speaker wiring.
Internal fault.
Regards.
Sep 23, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
JVC HX-C6 Shelf System Logo
389 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
