Question about Garmin GPS III
Have a garmin gps3 that will not power up - batteries checked OK. gps hasn't been used for a couple of years. replaced batteries with new - no go
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
IF it stil won't pwer up with the dc plug, I suspect the internal battery. Lots of info online on replacement, you can CAREFULLY snip one lead as a a diagnostic test to take it out of the circuit. Good Luck!
Posted on Feb 20, 2010
My garmin nuvi 1390LMT will not power on...any suggestions
After a couple of years without use, the batteries may be completely dead and take all the Chargers current and not power up.
Jan 21, 2015 | Garmin Nuvi 1390LMT GPS Receiver
I turn it on stays on for couple of seconds and shut back down, a couple of times it say battery is low, has been hooked up to 12volt power connecter in my car for close to 2 days
Your Nuvi 760 needs a new battery: rechargeables don't last forever.
Garmin's hope is that when the battery fails then you'll buy a whole new Garmin or will send it to them to be replaced, but it's a straightforward task to do yourself. Buying a new unit might make sense though if your unit also has outdated maps and/or outdated traffic/speed camera subscriptions.
A number of online suppliers have suitable batteries and there's more than one YouTube video showing you how to replace the battery. Click here for an example. Note that the same battery is fitted to the identical Nuvi 770, the only differences between the models is that the 770 has a larger internal memory to enable it to carry full US, UK and European mapping.
Please take a moment to rate my answer.
Mar 08, 2010 | Garmin Nuvi 760 Car GPS Receiver
I was given a garmin ique 3600 but i plug it in how do i know its charging
It lights up on top. Then the litle battery icon will show with a lightning bolt.
Nov 20, 2009 | Garmin iQue 3600 GPS Receiver
Hallo, Can anyone advise if an old Garmin 12 can be rescusitated if when turning it one all one casn get is a quick flash of the standard screen and then just a 'blue' screen?. (The batteries were still...
try putting fresh batteries in it and let it sit for 4 or 5 mins. then try to turn it on. mine did the same thing when i sat around for a year without being turned on.
Oct 31, 2009 | Garmin GPS 12 GPS Receiver
Replace internal battery on garmin gps3
Hi - I have a Garmin GPS 2 plus unit which is around 10 years old. I haven't used it for about 2 years. Initally it powered up and eventually found satellites. I switched it on the following day and it will not power up. I have changed batteries but nothing works - tried a master reset but agin nothing - it appears to be dead ?
Ali
Aug 29, 2008 | Garmin GPS
Unit will not turn on
Hello sympleman,
What you are describing may very well be a result of the battery going bad. The internal battery in your GPS receiver does have a limited lifespan. It is normal for the amount of operating time between charges to gradually decrease until eventually the battery pack does fail.
Unfortunately the battery does not appear to be replaceable by the user. To get the battery pack replaced you can contact Garmin directly. Their website is http://www.garmin.com.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 23, 2008 | Garmin Quest 2 GPS Receiver
Garmin C340 battery not charging
The Garmin batteries tend to die after about 2 years. Garmin will replace the battery for you but prepare to pay top dollar. It is a shame because the problem is commonplace. They should have made the replacement user friendly. The battery is buried deep inside and it is soldered.
May 06, 2008 | Garmin StreetPilot c340 GPS Receiver
276C Memory Battery
There is a button cell soldered to the main circuit board that powers the real-time clock while the unit is off or the main battery is removed or flat. After a couple of years this button cell dies and has to be replaced. I've had this problem twice in five years, and each time replacing the button cell fixes the problem.
Needs a Garmin workshop, or someone who's good with a fine-point soldering iron.
Jan 09, 2008 | Garmin GPSMAP 276C GPS Receiver
Garmin StreetPilot C330 GPS Battery
Pop the face plate off with your thumb nail right uner the Garmin logo. On the right side you will see a reset button. Depress it for 2 seconds. Replace face plate and power back on.
Nov 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin GPS III Logo
158 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
