Question about Shimano Deore Xt Thumb Shifters 7 Spd.mountain Bike
Deore dx shifter stops working
Shifter lever only allows me to use lower 3 gears before it stops "catching". I can push it freely but nothing happens.
Had the same problem, didn't use my bike for longer period. open the shift lever carefully and try something like caramba. worked for me.
sebastian
Posted on Sep 16, 2009
  • 12 Answers
The tiny moving ratcheting parts inside a shift lever assembly are packed with factory grease at the time of assembly by the manufacturer. Over time, this grease can become sticky, thicken, and harden to the point where the shifter's internal mechanisms no longer move freely. This is especially true of the shifter has remained in a single position over time, unused, like when a bike is put away in storage.
What has most likely happened in your case is one of the small ratchet "pawls" (or catches) has stuck "open", and is unable to "catch" on the rotating part that spools (or pulls) the shift cable that is connected to the derailleur. This is why the lever has very "free" feel through it's range of motion and is not able to "catch" on anyting to shift gears.
Fortunately the fix is usually very quick and simple. Free up the sticky internal parts by spraying a liberal amount of penetrating oil inside the shifter, heavily saturating all the internal parts. Move the shifter through all it's gear positions while doing this and 9 times out of 10, it will eventually free itself up and perform as good as new again.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_472b46f833fc3109
Posted on Feb 14, 2015
Same as halbganz mentioned... I have a Shimano STX (an old group, from th 90s). The bike was stored indoors, without using it for more than 8 years. Front shifter would shift from the small to the medium gear. When pushing the lever again to shift to the large gear, it went freely all the way back, without any resistance. Same thing happened with the rear shifter, I could shift from the small to the middle (4th) gear, but not to larger ones. After tinkering for a while, I put some WD40 in the shifters, through grooves and holes, without removing a single screw. It worked like a charm.
Posted on Feb 28, 2012
    President:
  • 1,138 Answers
Try the articles on this site:http://www.parktool.com/repair/readhowto.asp?id=117 Also check the derailleur articles.
Posted on Sep 11, 2009
I can only get 4 gears on a Shimano 7 speed. Shifter lever will only move three times.
Could be just an over-tight cable.. or the limit screws at the gear end over-tightened so that the selector does not transverse the full width of the gear cluster cassette...
Apr 09, 2014 | Shimano Deore Xt Thumb Shifters 7...
Chevy cavalier gear shifter
if it is s manual box remove the gear lever tower from the top of the box and see what damage was done to the bottom of lever and/or lever pivot pin in the tower. Remember normal gear boxes require a gentle shift to allow the syncro rings to work properly and if you want to do racing changes get yourself a specially built box.
Jan 02, 2014 | Cars & Trucks
My Shimano Deore DX mountain bike up / down shifter is malfunctioning. Any help will be appreciated.
Maybe start here and if you can't figure it out, take it to a Bike Shop. Ther's only so much useful mechanical advice one can remotely lend with no details.
Jul 03, 2010 | Shimano Deore Xt Thumb Shifters 7...
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Oct 07, 2009 | Mountain Shimano Deore Bicycle...
XT shifter will not shift
This link should help:http://www.parktool.com/repair/byregion.asp?catid=53
Sep 01, 2009 | Shimano Deore Xt Thumb Shifters 7...
1993 nissan maxima 3.0 standard transmision will not shift into first or second gear. it goes into all other gears fine and the clutch is working good. i disconected the shifter from the linkage and it...
try pushing the gear selector button in and pulling the gear selector into 1st gear position, if it doesnt catch, leave it aligned with the "1" on the panel, let go of the button, then once the gear selector (shifter) is staionary int he 1 position pull back on it slightly without pusing in the button..
Hit the gas and see if it catches.. it is likely, you have a worn catch for the two gears that aren't grabbing.. if you hit speed bump or pot hole you may have to pull back on it genly while driving to get the gear back...
Let me know if this works
May 14, 2009 | 1993 Nissan Maxima
Shimano Deore Xt Thumb Shifters 7 Spd.mountain Bike Logo
1,454 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
