Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 DLP - adjusting low-level grey
I recently reapired two WD-62525 DLP's by replacing most of the caps on four boards. In the service menu, I can adjust the hi-level color drivers (GGH, GBH, GRH), but the settings won't budge for the medium and low-level colors. Shadows are green. This is most prevalent using a cable box with the HDMI port. However, using the component jacks instead, the contrast is beter, the colors look good, but I see rolling red lines in the picture - on both sets.
Any way to adjust the low-level color drivers?
Or, get rid of the red rolling lines?
Thanks,
Dan
2 Suggested Answers
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
My Mitsubishi WD-62525 wont even turn on. No blinking lights or anything. Power Board bad???
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options for you. 1. Have it fixed by a professional 2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It'scalled: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.Kaufman605
Dec 11, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Getting error code 12 on mitsu wd 62525 dlp tv. any help would be great.
12 means no error detected. What are the symptoms of the set? If its the blinking led thats the DM caps which have failed.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Im getting error code 34 on my mitsubishi tv wd 62525.
Heres a link to the kit which will repair that issue. The kit contains the replacement capacitors and the step by step instructions with pictures. Heres the link to the proper kit.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Best settings for moderate to low light viewing?
Using your remote, click the "video" button (mid area, Right hand side) and adjust the brightness, contrast, etc., to your liking. Only you know what you like. If your picture can be "plenty bright enough"...then just make the necessary adjusts to whatever looks best to you. If your picture is "very dim" no matter what the video settings are, you need a complete cleaning of all lens, mirrors, and screen...and possibly a new lamp.
Apr 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62628 Mitsubishi DLP
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Oct 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Jul 28, 2008 | Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
