Question about GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel
What is blue wire on ge built in oven for - GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Posted on Dec 04, 2010
How does one replace the oven temp sensor?
Pretty easy, usually located at rear top of oven, one screw holds bracket, so remove, then you will see wire, pull it out to access connector, replace with new one, plug back in and replace bracket. My GE was easy fix and sensors are low cost.
FREE-PPV.com
Jun 03, 2015 | GE Profile 30" Built-In Single Electric...
Will a GE built in oven JT3000DF fit in the space that has a Kenmoore build oven in that space at this time 9114105559 part number
Simple. Measurements. Unless i'm missing something here.
Take present oven detailed measurement, compare it to the newer oven's detailed measurement.
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
Ge true temp oven
Sometimes you will have to pull the oven out to get access to the connector for the sensor. It could be jammed in the back or the hole is just too small to pull the connector through the wall.
Feb 15, 2014 | Ovens
F3 keeps flashing on the display
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | GE 30" Built-In Single Electric Wall Oven...
Need wiring diagram for part number WB27T10276 for ge oven model JRS04BW3BB
For anyone installing a replacement oven controller #WB27T10276, there is a GE publication # 31-10515 that should answer your questions. I bought a rebuilt control that did not have this info. with it. Lucky for me, a retail appliance parts store opened a box with a new control in it and copied the instructions for me.
Aug 14, 2010 | GE 24" Built-in Single Electric Wall Oven...
PURCHASED NEW GE WB27T10327 OVEN CONTROL TORISAN ERCB3 DID NOT HAVE INSTRUCTIONS FOR A NON SELF CLEANING OVEN. CAN YOU HELP? JERRY
Hi.
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
Nov 06, 2009 | GE 24" Built-In Single Gas Wall Oven
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel Logo
363 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
