Question about Cross Furnace Draft Inducer Blower 115 Volts Fasco # A064
Outside unit turns on but inside wont. fan is real hot
  • 62 Answers
I would suggest replacing your induced draft motor. You can perform an amperage draw test to verify it's integrity first. Also check your high limit snap disks before spending money.:)
Posted on Sep 08, 2009
Thermostat inside went up to 78 degrees which was set for 73 degrees. I checked filter filter was clogged. I cleaned filter. However could not get outside unit fan to go on even after turning off for 20...
Did the circuit breaker trip or did you turn it off and back on? If you had to remove the blower door to get
to the filter make sure the door is secured because
the door has a rocker switch that powers the entire unit.
Jun 17, 2010 | Heating & Cooling
Rick55 my outside unit goodman cjk484ab stopped working fan not turning motor very hot power went out for asecond then the unit stopped working i think the fan motor went out
check the capacitor if motor is real hot it might be burnt out winding can you get it to turn buy pushing the blades if so good chance it motor.
Jun 24, 2009 | Heating & Cooling
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Air conditioning not working
Turn fan to on position to see if it comes on. If you amy have a bad fan relay ot fan capacitor. Need to call service tech sorry
Jun 15, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Goodman split unit that heats instead of cools
Hi, Could be a run capacitor on the fan motor. They usually swell up and or leak when they go bad. If not, the only real way to test them it with a specific capacitor tester. A new capacitor would be cheaper. Make sure that the outside unit is disconnected from power before opening it up, try to spin the fan blade by hand. If it doesn't spin freely it may need oiled if possible. See above solution. Your problem is the fan motor though so if this don't do it, It will have to be replaced. If this helps, Please rate my solution. Thanks, kstfas
Aug 31, 2007 | Heating & Cooling
Cross Furnace Draft Inducer Blower  115 Volts Fasco # A064 Logo
119 people viewed this question
Top Cross Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cross Measuring Tool and Sensor Expert? Answer questions, earn points and help others
