Question about QSC ISA 300Ti Amplifier
QSC ISA 280 Stereo Power Amp stopped working
My QSC ISA 280 Power amplifier stopped working. When I turn it on the Power LED turns on but the signal LED's don't react to the input and the Speakers let out a soft hum no matter the volume of the input (or if there's input at all). At first this would happen and the power amp would start up after some time, but now it just stays in this state.
    Scholar:
  • 148 Answers
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Posted on Sep 08, 2009
    Problem Solver:
  • 6 Answers
I am a Pro Audio/Video Installer... I certified by QSC and install their products regularly so I must disagree with the previous solution by saying MOST sound shops will not delve into this... Most shops or QSC themselves usually recommend replacement. My best advice is try to isolate the problem Input side vs. Output side. Start by unplugging everything from the amp both speakers and your inputs. Then plug in each channel for speakers individually to see if the problem is following a channel. If you do not find the "hum" at this point when each channel is tested individually and then together, your outputs should be ok but still more testing... Now plug in individual inputs... ALL to be exact 1/4" TRS, spade terminals and XLR's. Continue this to isolate the problem... if no single channel IN or OUT can be identified then the unit probably has much more problems internally and trust me the cost of Repair VS. Replacement would find you replacing much more cost effectively! I hope I helped!
Posted on Aug 10, 2011
  • Nick Bellos
    Nick Bellos Aug 10, 2011
Qsc usa 900 power amplifier coming on but no signal.what can be the problem.I check all outputs
Are you then saying you have no sound, yet the amp is on? If so, with the unit off, listen carefully to the top of the amp. When you first push the power button, you should hear one click, followed by another click, about 5-20 seconds later. I'm guessing you hear the first click, but not the second. Is that correct? If this is correct, and you are interested in having your QSC repaired, Please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jan 22, 2015 | QSC Audio Players & Recorders
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
When first turned on the left clip led is illuminated-no sound
Try spraying it with contect electric cleaner it worked for my amps
May 19, 2012 | QSC GX5 2Channel Amplifier
Amp sound cuts out after a short while but power
what do you mean the switch has been disco'd? how do you turn it on or off, then? check the contacts in the jack for the effects loops, and make sure they are clean and making appropriate contact for the tip to shunt/ground and sleeve to ground contacts. also the big resistors on the pcb should be resoldered as they may have cracked solder joints.
Dec 23, 2009 | QSC ISA 300Ti Amplifier
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
QSC 1420 pwr amp
The weaker signal caused by leaky capacitor and change value resistor is need to replaced with a new one so it's works normal again. Your tech did is re soldering the cold solder he did not replaced some defected parts.
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | QSC MX1500A 2-Channel Amplifier
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
522 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
