Question about Panasonic NN-P794SF Microwave Oven
My panasonic NN-T945SF starts, runs for a few seconds and then shuts off. And I smell rubber burning.
  • Panasonic Master
  • 9,047 Answers
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Sep 12, 2009
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Code on screen H-98 wont run
www.panasonic.com/.../troubleshooting-failure-co
Jun 16, 2014 | Panasonic NN-T945SF Stainless Steel 2.2...
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
The microwave starts, then stops after a few seconds, and smells
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Sep 07, 2009 | Panasonic NN-H504WF Microwave Oven
Purchased a panasonic NN-H965 microwave and yesterday when using it, it started making the following noise: upon starting, the unit works for 3 seconds with funny noises and then it stops. There used to be...
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Aug 26, 2009 | Panasonic NN-H965 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Burnt Rubber Smell then Off
That would most likely be a problem with the inverter or magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Panasonic NN-H664 Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
1,109 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
