Question about SanDisk Sansa m240 MP3 Player
I have a sansa m240 that I haven't used in a long time. i wanted to remove all old music and put new on, but when i hook it up to my computer it doesn't show that there is any music on it, but i have over 100 songs on it.
    President:
  • 392 Answers
Format the removable device beacuse you anyways want to remove the old songs.
Posted on Sep 08, 2009
    Scholar:
  • 44 Answers
Well i think solution 1 and 2 have their ponts... u might have reset it by mistake (or someone else did) and bec ull put new songs in it, it shud be okay....as long as there are no errors or other problems other than that
Posted on Sep 12, 2009
Did you happen to reset it by mistake? email me at lgyinv@verizon.net
Posted on Sep 09, 2009
How to put music on sandisk sansa
Connect your player to the computer using the USB cable provided. Drop your songs into the removable device that gets detected.
May 20, 2010 | SanDisk Sansa m240 MP3 Player
How do I remove existing music..?
Hi There,
You follow this step:
  • Connect your Sansa Clip player to your computer.
  • Select Open device to view files using Windows Explorer on initial connection.
  • Double-click on the Sansa player.
  • Double-click MUSIC folder.
  • Delete music that you want to remove from MUSIC FOLDER
I addition: you can read User guide here:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Goodluck :)
Apr 19, 2010 | SanDisk Sansa m240 MP3 Player
Put music on mp3 from computer
  1. dowload this coverter tool.
  2. instal the program .
  3. open the program.
  4. select the music's that you want
  5. covert the music's that you want
  6. copy the music's to the mp3
  7. done , hear the music's
here is link to download the program :
http://superdownloads.uol.com.br/download/100/free-wma-to-mp3-converter/
please rated my solution...
Feb 06, 2009 | SanDisk Sansa m240 MP3 Player
How do I reset or clear all my music files on my Sansa m240?
connect your M240 to your computer via the usb, go to My Computer and you should see it listed there as M240. Double click to open and delete the files you want to remove.
Or you can use windows media player .. by going to FILE, OPEN and choose the M240 (will located under My Computer).
Mar 09, 2008 | SanDisk Sansa m240 MP3 Player
MY MP3 WON'T WORK!!!!HELP!!!!
go to my computer and select removable disc (thats your mp3 player) then click and drag songs to the music file in the removable disc icon. This is how my friend does it with most of his mp3 players.
Jan 21, 2008 | SanDisk Sansa m240 MP3 Player
Deleteing music from m240
-Plug your mp3 player into your computer using a usb cord.
-Open My Computer and look for a folder named Sansa"something".
-Open this folder and go into the desired folder[music] where you would want to delete music.
-select a song or multiple songs and press delete.
Dec 25, 2007 | SanDisk Sansa m240 MP3 Player
not the best solution perhaps, but I just formatted the disc and all data is gone. Had to do it as for some reason, the old music files weren't showing, but disc space was taken.
Dec 13, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
CANT DELETE!
Hi Trixxy, It's quite simple. Connect the Sansa to your pc click on "my computer" poitn on the Sansa drive and right click "Format". This will restart your Sansa. Let me know if it worked and please rate this comment. Best, D.
Mar 27, 2007 | SanDisk Sansa m240 MP3 Player
Sansa m240
Hi. I'm having the same problem with my m250 and am concerned, since I've only had it for a month. Nothing I do, including removing the battery, hooking it up to my computer again, or holding the power button down for a long period of time works.
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
143 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
