Question about Poulan "Poulan" Push Mower
The idle is not smooth, how to I fix it? - Poulan "Poulan" Push Mower
  • kevin846
    kevin846 May 11, 2010
    Can you supply engine make and model please? If Briggs & stratton there are 3 numbers - model, type and code - I just need the model and type..
  • 784 Answers
1- Replace the air filter.
2- Mix a little Fuel injector Cleaner in your fuel tank. It works like a champ. Note although your mower has only carburator, but the this cleaning works very well.
Posted on Sep 08, 2009
My 1997 mitsubishi galant idle to low and sometimes cuts off. How to fix it?
clean the throttle body intake, should help, idle setting has changed due to dirt build up
Apr 18, 2013 | 1997 Mitsubishi Galant
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
I got a 1999 ford ranger with a 2.5l it runs smooth at idle, an runs smooth while drive but bad fuel economy. when u rev up at idle an let go of the throttle it runs rough an then smooths out. ive...
You have two coils on this engine. Test each wire for spark with the engine running. You'll find at least one wire not sparking. replace the coil that has the wire that's not sparking.
May 14, 2011 | Ford Ranger Cars & Trucks
93 GSX 750f wont idle w/o choke
sounds like a bad diaphram in one of the carbs
Jul 13, 2009 | 1993 Suzuki GSX 750 F (Katana)
1994 ford escort vibrates horribly in idle, does not stall. Idle is set @ 800rpm, runs smooth when raised to about 1200rpm. Suggestions?
Your Idle air control valve is probably going bad. It is located on the throttle body and is a relatively easy fix as it is only held in with 2 screws. Good luck and thanks for using FixYa!
Jun 27, 2009 | 1994 Ford Escort
I have a 1994 gmc safari.It seems to have a smooth idle at times
Im not sure if you got it fixed yet! It could possibly be idle air control valve. But here some more suggestions! I had a 94 Safari van 4.3 liter I was working on for about three days and I finally figured out what was wrong with it. It would run fine for a couple minutes and as soon as I hit the gas and let off it would surge, but anyways I ended up changing the distributer, after the fuel pump and filter, mass air flow sensor, egr valve, idle air control valve, map sensor, and ignition module. So that might sove the problem if you were on the same track with it as I was. Hope this helps ya!
Mar 02, 2009 | 1994 GMC Safari
Idle problem
you got it . it is more than likely you have vacuum leak . to chek use a propane torch and while idling intoduce propane at possible area(intake gasket, egr valve , brake booster etc) if idle speeds up and smooth fix it.
Jan 28, 2009 | 1991 Toyota Pickup
Poulan "Poulan" Push Mower Logo
162 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
