Screen only flickers, power light blinks slowly
Screen only barely flickers once in a while, power light blinks on and off slowly. doesn't matter if it's plugged into the computer or not.
    Sniper:
  • 58 Answers
Need to change or repair monitor at this stage.
Posted on Sep 07, 2009
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
My samsung was hit by lighting.. the red light blinks a few times when i plug it in. and when i press power it blinks once. but will not turn on. i checked the two fuses inside and replaced them but i
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 23, 2014 | Samsung LN Televison & Video
No picture just black screen
sounds like the lamp went out in it. change lamp and u should get sound and picture
Apr 23, 2013 | JVC HD-52G886 52" Rear Projection HDTV
During a thunderstorm, the power flickered off for an instant with the GPX D1816 in standby mode (red light?), but now the standby light is blinking green and it will not work.
If the indicator light is blinking it is probably a faulty power supply. I just fixed mine today. Open the player up by removing the Phillips screws and locate the power supply board - this is the circuit board that connects directly to the incoming 120 Volt power. On this board look closely at the barrel shaped capacitors and note any bulging at the top of these capacitors. My 1000uf 16volt cap was just barely bulging so I decided to replace it with a piece salvaged from an old PC power supply. It is simply a matter of de-soldering the old piece and soldering in a new one. If you must purchase one you could probably get one from Radio Shack or Digi-Key for under a dollar. The replacement should be 1000uf and rated for at least 16volts or more.
Jun 17, 2011 | GPX D1816 DVD Player
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
Laptop screen blanks out
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 02, 2009 | EliteGroup ECS G900 Notebook
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Vizio 50 inch plasma picture problem
Hope you all have extend. warranty... Good luck
Jan 15, 2008 | V, Inc. Vizio P50HD Plasma Television
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
