Question about Dishwashers
Water left in bottom of unit after cycle finished. Not able to use rinse only.
    Brigadier General:
  • 4,088 Answers
Remove all components from the lower spray arm down to the deck noting the position and orientation of each part. At the bottom, remove a large screen--soak it in a hot water and white vinegar solution (5 to 1 ratio) for an hour or two. Scrub the screen to remove water and food deposits. Disconnect the drain hose under the sink and blow through it with either compressed air or a vacuum cleaner set to blow in order to remove any debris in the hose or pump. Reassemble the components in reverse order and test the repair with a trial run--no dishes.
Posted on Sep 07, 2009
Testimonial: "Thank you; we'll try it!"
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Wont finish wash and drain
I would turn off main power then open the controls looking for any burn parts on the power board before calling any one , how ld is this unit before yu spen too much get back to me
Dec 04, 2011 | Electrolux Dishwashers
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
I have an ASKO W6021 Quattro 1200 RPM. It does not complete the wash cycle. If I turn the know to rinse, it does rinse and completes. I tried it without any clothes in it and it does the same thing. I also...
Check that the cold water is turned on. The washing machine uses cold water to rinse, and if the cold water is not on, unit will end without completing cycle.
Mar 14, 2011 | Asko W6021 Front Load Washer
I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
Won't finish cycle
The water may not be getting hot enough in the rinse cycle. Usually it needs to heat to 140 to 160 degrees for rinsing. If the heating element is not working the water will not heat. If your DW has a Sanitary setting it will be calling for the water to be 160 degrees. If you have the option to override the Sanitary settin, try that to see if the rinse cycle will finish with cooler water.
Mar 27, 2010 | Dishwashers
Dishes are not cleaning and a filmis left on the
Use FINISH detergent with built in rinse agent.
Water should be at least 140 degrees.
is there a LOT of water in the bottom of the machine after cycle?
Jun 27, 2009 | Dishwashers
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Rinse cycle
Is the unit new or used?, or does it wait and then go ahead and finish? This would be normal if it finishes on its own. Some units let things settle between cycles. If you have to nudge the control past a point then to make it finish then it is a problem which would require that the control be replaced. If it used to work different then it too would most likely be the control unit. There are numerous contacts and combinations that change from one setting to the next. Bottom line, does it get the clothes clean?? If it does the don't fix whats not broken...
Jan 26, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
