Question about Bose RC-18S Remote Control
My bose 321remote will not work. i have tried to replace the battery and it still will not work. there has been no battery spilage either but it will not work. Not sure what to do
    Novelist:
  • 133 Answers
Try this:
Insert a new battery and check if the remote works, you can do so with a camera on the mobile phone, just activate the camera, point the emitter on the remote towards the camera lens so you can see it on the mobile's display, now press buttons on the remote - if the remote works you should see a flashing light on the mobile's display - this is the infrared LED in the remote, which you can't normally see, but it's being converted into visible light by the camera.
If the remote flashes even when you don't press any buttons then there is a stuck button and you'll need to clean the remote housing and the rubber keypad with some ethyl alcohol, also clean well the holes where the buttons protrude, there may be dirt keeping a key pressed stuck.
If there are no flashes when you press the buttons, then check the battery connector on both ends, see if there are any broken wires and resolder or replace the connector if necessary.
Also check inside the remote - there will be some soldered components - check if ANY of these have a bad solder contact, pay extra attention to the LED pins, these often get loose with time, resolder any bad contacts (you can check if the LED is good with the diode test on a multimeter, it should behave in the same way as a standard diode or LED - conductive in one direction, blocking in reverse).
Other things you may want (or need) to do: clean the remote housing and the rubber keypad, also clean the contact tabs on the keypad and on the circuit board, but do it gently, you don't want to damage the conductive coating.
This is about all you can do by yourself, but if you think your remote is in some kind of a stuck program state, you can TRY to reset it (i'm not saying this is actually gonna work - it' does with some remotes, but i can't say for sure).
This is how you do it: remove the battery, disassemble the remote, take a piece of aluminum wrapping foil and place it over the main IC (chip) pins so that ALL the pins on the IC are in contact with the foil at the same time.
A few seconds of contact should be enough.
Keep in mind: any of this may or may not work. I don't actually know what the trouble is, i just suggested a few things you can check and repair by yourself.
Anyway, i hope you can fix it.
regards
3rq8 (Triarcuate)
Posted on Sep 08, 2009
Sound stopped mid program cannot get it to work--replaced and cleaned battery compartment to no avail.
Try going to the BOSE webside where you can use their manuals, or videos or get in touch with their Contact Us tab
Bose Solo TV sound system Bose Product Support
Sep 05, 2015 | Bose Solo TV sound system - Black
Bose instructions
Sounds like the battery is dead. Time to replace the battery. Is it under warranty? If not, then buy a replacement battery from Bose.
Here's the "How to" for battery replacement: Bose SoundLink Mini BLUETOOTH speaker Bose Product Support
Aug 26, 2014 | Bose Corp Bose SoundLink Mini
How do I reset the bose remote
First, replace remote unit's battery. Worn out batteries can partially scramble the data.
Jul 19, 2014 | Bose Audio Players & Recorders
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
My Bose QC15 won't turn on, I've already tried replacing the battery. What could be the problem?
Mine did this as well, totally frustrated I kept on rapidly switching them on and off, and eventually it just switched on!
Mar 25, 2012 | Bose QC15 Headphones
I ordered and received a new remote for my Bose radio. Mine is the old type purchased in 1997. My problem is the new remote does not work, and yes it did come with a battery. Is there something you can...
The old and new remote look alike?Not than it have diffrent radio frequencies.The remote will not work,with the Bose radio you have.Call bose custumer service,ask the remote the match ur Bose radio make and model.Return the remote u have,get a replacement matches ur Bose radio model or look alike to ur old remote.
Sep 04, 2010 | Bose Televison & Video
Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Dec 26, 2008 | Bose Wave Radio
My bose 321 system remote control sometime works and sometime doesn't.
When we try to use the remote the red light glows which I never saw glowing when it was working properly.What could be the problem?
Jan 03, 2008 | Bose RC-18S Remote Control
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Bose RC-18S Remote Control Logo
784 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
