Question about Dishwashers
Dishwasher not working
The last time my whirlpool dishwasher ran (yesterday), there was a strong burning smell at the end of the cycle. It smelled like burning rubber, or electrical. We tried to run another load today and the dishwasher will not run. There does not appear to be power to the dishwasher - the control panel lights aren't working either. Is there a reset wwitch somewhere? Is the motor burned out? Is it worthwile to have it repaired (it's about 5 years old) or replaced?
  • 10,865 Answers
The motor may be burned out or there may be another electrical issue which would also cause the symptoms you describe. Call around and try to get an estimate, and at the same time look at new ones on sale.............one question is how secure will u feel with that maching......now that it has acted up like this.
Posted on Sep 07, 2009
Have a whirlpool dryer type dwsr ele 2406026-cv54 / mod wed4900xvo , we get a burning smell on all items
  1. Ok, bare with me...
    Is there any visible SMOKE with the smell? If so turn it off and call a repairman.
  2. Verify that the clothes drum is turning freely. If it is not, call a repairman.
  3. Otherwise;
    I recommend removing all clothing from your dryer and to carefully follow these instructions.
  4. With the machine off, Clean the dryer filter well. Set dryer to the MAXIMUM heat setting on a 30 min TIMED cycle.
  5. Start the cycle.
  6. Make close observations in short intervals of time.
  7. At the end of your timed cycle determine if the smell has changed more or less.
  8. With the dryer off, Locate the electrical socket/plug of the device if it is an electric machine. place your hand on it to determine it's temperature. It should be no more than Luke-warm to touch.
  9. If it is uncomfortably warm to touch you should consider contacting an electrician to determine the working load of the wiring to the device.
  10. If the wiring/plug test is deemed adequately cool, ventilate the dyer area well for an hour and repeat steps 3-7, the hot - empty test again. The smell should diminish.
Lint and other clothes debris can get pulled into contact with the dryer's heating element and it will burn or smolder. If a piece of elastic rubber gets into contact with the heating element, the smell will be strong and may last a long time.
If it is still bothersome after the burn-out procedure, it will have to be taken apart and at least cleaned or the element replaced. This is not usually covered by warranty as it is considered a USER PROBLEM. Sorry.
Mar 29, 2017 | Whirlpool Dryers
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Nov 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Dishwashers Logo
625 people viewed this question
Top Dishwashers Experts
