GE GSS25JEMWW Side by Side
Problem for GE GSS25JEMWW Side by Side
We have a GE refrigerator that is leaking
By jetoneil on Sep 07, 2009
We have a GE refrigerator that has a water and ice filter in the door of the freezer. Water is leaking from a hole in the bottom back corner of the freezer. It looks to be a possible overflow?
Solution #1
posted on Sep 07, 2009
Not Rated)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 621 votes
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Was this helpful?
Yes
No
Popular Solutions for GE GSS25JEMWW Side by Side
Questions and Unsolved Problems for GE GSS25JEMWW Side by Side
Do you recommend GE GSS25JEMWW Side by Side?
Answer
Answer
the water leaks in the refrigerator and will not fill for the ice maker
Answer
the ice maker is producing ice but water will not dispense through the water dispenser
Answer
ge gss25jfph ww side by side. finally hooked up wtar line. water dispenses. no ice being made? looks... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
