Question about Garden
Change belt change the top drive belt on model 13ax605g755 it has 3 pully's the belt has to fit on
  • 62 Answers
I find it easier to drop the deck. There should be clevis pins or cotter pins holding sever arms to deck. :)
Posted on Sep 08, 2009
How to change serpentine belt on 2006 buick lacrosse
Start by drawing a diagram of the belt routing. Serpentine belts normaly have 1 spring loaded tensioner (1 pully will have a nut or 3/8 or 1/2 inch drive hole) That will be the tensioner. get spanner or ratchet to fit & lever the tensioner away from the belt. Remove belt. fit new belt to most pullys except the easiest to get to, lever the tenioner back & fit the belt to the last pully, Check the belt is on all pullys properly & your done
Jun 28, 2012 | Cars & Trucks
I have a 1980 FXWG (not a sturigs) but it does have rear belt drive. I need a trans the 1 thats in it is a roto top (cow patti ) what trans will fit now . does trans have a long shaft for belt pully
According to what my parts book shows, there was not a different mainshaft for the belt drive. All models used the same mainshaft from 1970 to late 1984. Harley offered a kit, 35039-80, that retrofitted the 1970 and up to late '84. I know the 1965 through 1969 is shorter and won't work. Then in 1984, they changed it again leaving off the kick start provisions. They only made three mainshafts so any rotary top transmission should fit your bike as far as I can tell. What is wrong with your transmission? Can it be repaired?
Good Luck
Steve
May 22, 2011 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
How to change the serpentine belt on a 2002 GMC Sierra HD2500
Look for the belt tensioner pully. If you don't know what this is run the engine and look at the pullies.The one you want is the only one that will be moving up and down.This is the one that is spring loaded.Think it is drivers side top.It may have a square hole in the arm to put a ratchet in.Thinking 3/8" drive but may be 1/2" ,if there is not a hole then you will need a socket that fits on the center bolt of the pully.I will suggest a long handled ratchet or breaker bar,if you don't have one you can put a pipe over the handle of a short handle."cheater pipe"Put force on it so the pully comes up off the belt.If you don't have a belt routing sticker still on your radiator shroud draw one before you remove it.I think the belt comes off on the drivers side.when putting on the new one start at the crank pully,around the waterpump,then to all pullys on passinger side.The last one will be the alternator.Hold the belt down in front of the tensioner pully attach the ratchet and pull until you can slip the belt under the pully,Make sure the belt is properly seated in all pullys before starting.Helps if you have a spare set of hands.
Oct 29, 2009 | 2002 GMC Sierra
Need diagram for instaalling serpentine belt on 1989 chevy s10 2.5 engine belt broke and no diagram
Picture is for the carbureted model but has the same patter as my fuel injected model. It's actually pretty easy to see how it goes. If the pully has groves then the grove side of the belt will fit right in it prefectly. If it's smooth then the back side of the belt with run along it. To loosen the belt tensioner do two things. first in the picture below you will see in the top middle you will see the tensioner. The back of the belt runs along it. You will notice that it looks like a solid peice. loosen the top slighty with i believe a 15mm. After that connect to the pully attached to it and pull back to the passenger side until you can slid the belt off the alternator. put back on in reverse order. really really simple once you do it. good luck
Oct 11, 2009 | 1989 Chevrolet S-10 Blazer
How to replace the belt on a beko washer
Hithere.......the belt used on these machines is a stretch belt...ie...it will require a little determination to fit it......Isolate the electricity from the machine....remove the top lid.....remove the rear inspection panel...(5 screws) from the top of the machine offer the belt down to the motor pully...fitting it over the pully (middle of the motor pully)...bring the belt as far around the drive pulley of the washer as you can...then holding it in place gently turn the drive pulley this action will bring the new belt fully over the drive pulley...check and aling the belt in the middle of the washer pulley
BE RATHER CAREFUL NOT TO CUT OR LACERATE UR HANDS
Regards Sir Galahad
Aug 16, 2009 | Washing Machines
John deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Jun 30, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Belt drive replacement
First you have to remove the top cover over the belt. If it's still on, work it off the pully. Then you have to remove the blade, blade adapter and cover underneath. Put the new belt on the pulley underneath and push it out the slot to the pulley on top and put everthing back together. Hope that helps.
Apr 29, 2009 | Craftsman Garden
Hotpoint wf240 replacment of belt, i cant get it on.
Hi, put the belt on the bottom pully and feed the rest up to the top pully, fit the belt on to half of the top pully, now open the door of the washer and very carefuly turn the drum while holding the belt tight to the pully, take care not to get your fingers trapped, make sure that the belt stays on both pullys by rotating the drum by hand a few times, if it all looks ok and central then the jobs a good un.
Mar 03, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
