HOW TO LINK A OLD TV TO DVD WITHOUT SCART
My OLD LITTLE TV HASNT GOT SCART JUST ARIAL,VIDEO AND AUDIO SOCKETS AT THE BACK HOW CAN I LINK UP A DVD PLAYER/FREEVEIW ECT
    Scholar:
  • 148 Answers
Use a VCR in between and use the vcr auxiliary input to connect to your dvd. Then out from the vcr with good old coax cable...
Posted on Sep 08, 2009
How to connect to DVD,VCR and TV
DVD connects over HDMI, VCR to RCA left and right and video in.
Jul 16, 2015 | Sony Str De545 5.1 Channel 100 Watt...
Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Jan 23, 2012 | Toshiba Televison & Video
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
How do you connect the outside antennae to both the dvd player and digital converter box and the television
if its a dvd recorder first connect arial to recorder,then connect arial out to arial in on next device,and so on,it will say uhf in and out,on back the tv should be the last one connected,and you can also link them using scart leads and then use av on remote control, hope this helps andy
Jun 22, 2008 | Televison & Video
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
