Question about SPL Car Audio & Video
I need to kow how to set my spl 1440 acoustic to stereo from mono
2 Suggested Answers
BDEATH
  • 58 Answers
SOURCE: Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Posted on Sep 04, 2007
How to switch from stereo to mono jvc mxgt700
Most there is not a switch--set selects automatically and it will often be in mono if signal a little low or set does not detect it--Seen several where it said mono but was actually in Stereo.
Apr 18, 2012 | Sony Televison & Video
I need a diagram showing how to connect the Digital Media Theater to the speakers and computer
i have found some posts on your speakers very nice anyway hope this helps
Just found an RCA to mono mini adapter and rca cable, plugged it in, and it works great. I notice a very slight difference in sound, for the better.
It's a digital cable, stereo/mono don't apply. It should be a single 75 ohm coaxial cable. Not a tip ring sleeve stereo cable. Any old RCA coax cable (with the appropriate 1/8 in. mini mono adapter) should work.
I attached a picture of the back, it is blurry, but you can at least see what it is. (top right jack)
May 07, 2011 | Boston Acoustics MediaTheater Computer...
When I use the headphones listening to TV, I get the background sound (eg music) clearly but the dialogue is very low and drowned out by the background music or ambient sounds
It's because the TV's audio is stereo and the dialogue is mono split between two channels. When dialogue hits your headphones the majority of the mono signal gets cancelled. Try a different set of headphones or watch true stereo channels... IE movie channels
Apr 18, 2011 | Bose QuietComfort 2 Acoustic Noise...
Parker fly acoustic pickup quit. When the red button is depressed all my gain is gone from the magnetic pickups and from the acoustic pickup.
If you are using a mono (2 contact) guitar cable then the output from magnetic & piezo pick-ups should be mixed together. If you are using a stereo cable (3 contacts - tip, ring sleeve) then it will be stereo with one signal sent down each core of the cable with common/ground on the sleeve.
If you are using a stereo cable into a mono amp socket it is possible that a short is occurring, which would cut the signal. I would also check your cable for poor/ shorting connections. The signal level could also drop if the pick-ups were out of phase with each other.
For more information on balancing the levels between the pick-ups see the user's manual here
http://www.parkerguitars.com/images/stories/manuals/Parker_Manual.pdf
Feb 10, 2011 | Parker Fly Deluxe Guitar Electric
I have an spl 1440 watt amp model st2-1440 that i cant get to turn on without 15 volts to the remote wire and then it gets really hot really fast. Any ideas why or how to fix it?
Generally a battery puts out 14.1 volts to the amplifier. The only way your amp would get really hot really fast is if the amp was configured to run at to low of an ohm load.
That amps spec is to run at 2 ohm stereo. But I do see an option to get 1400 watts with 2 ohm mono, but that would require 2 dual 2 ohm subs using only one voice coil bridged to the amp. If you run both subs with both voice coils in parallel you'll get a 1 ohm load and that will overheat your amp.
Reference: http://www.sweetwater.com/forums/archive/index.php/t-2193.html
Ohms are the units that impedance is measured with. You can kind of think of impedance as the measure of how hard the amp has to push to get current to flow. The lower the impedance, the more power will be output from your amp. Unfortunately, the amplifier circuit wants to push against something, so that if the impedance is too low, the amp can perform badly, and even overheat and burn out.
Hope this helps!
Aug 01, 2010 | Car Audio & Video
Trying to set the time on a timex 1440 that someone gave me second hand. I am in Lima Peru so the automatic time change doesn't work. I don't kow what all the little icons at the top stand for either.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 17, 2010 | Timex 1440 watch
I want wireless speakers for a 25'X 30' room to connect to a stereo. would the Acoustic Research be powerfull enough. Are the two speakers truly wireless or do the need to be connected to each other
they are wireless but need to be plugged in for power. or batteries. can be used as mono or left and right. i sell these spkrs and have had no complaints. hope this helps.
Jul 10, 2009 | Acoustic Research 900MHz Wireless Stereo...
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
AC-740 : No Manual
does it have 2 plugs one for mic and headset or sterio plug for mono head set mono mic u would need input on phone that can accept that kinda sterio input ok for both
Jan 28, 2008 | Cyber Acoustics AC-740 Headset
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Car Audio & Video Logo
43 people viewed this question
Top SPL Car Audio & Video Experts
xxxxxx xxx
Are you a SPL Car Audio and Video Expert? Answer questions, earn points and help others
