Question about Artograph Projector Bulbs 100 watt - RT210, Tracer, Tracer Jr. Projector Lamp
I can't find the bulb for my old eumig p8 automatic projector, looked every where, it's a 4 pin bayonet 12v 100w blacktop
  • Anonymous Mar 31, 2014
    Manual
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Have you tried Projector Doctor on the web? Their toll free number is (800)789-9820. They advertise 24/7 support. Also, All Projectors.com...(800)901-8684. Free calls...start there--they probably could point you in the right direction!---Rick
Posted on Sep 07, 2009
I need a claw arm for a EUMIG MARK 822 projector.
Sorry we have no parts for sale here.
Jun 27, 2017 | Cars & Trucks
What type of bulb do I need for a Piaggio Zip 50 tail light?
They have seperate stop light bulbs to the tail light which is the uncommon.I think the stop bulbs are 12v 4 watt wedge fit sidelight bulbs,they use them in cars too as sidelight bulbs.the tail light one is a 12v 10 watt bayonet type.
Mar 06, 2015 | 2010 Piaggio Zip 50
I have a minolta autodual 8 film projector but the front reel is turning backwards in the wrong direction. How do I change the direction to turn in the same direction as the back reel.
I assume you haven't put a reel of film onto the projector and looped it through to the back spool. The front spool usually 'freewheels' whilst the film is pulled through the projector and taken up by the motor driven rear spool.
It is possible that the friction drive and/or drive belt have deteriorated with age, as the mentioned projector is a rather elderly 'classic' of the dual 8mm series.
If in doubt, don't risk your family pictures. Try the unit with an old piece of film on small spools.
Dec 26, 2014 | Eumig Imperial P8 Movie Projector For 8mm...
Elmo st600
The bulb you need is this one:
100W MR16 12V GZ6.35 BASE 64627 HLX OSRAM
You can try to buy it from here:
http://www.atlantalightbulbs.com/ecart/10Expand.asp?ProductCode=ELMO-VPD100ST600ST800#page=description
May 10, 2014 | Office Equipment & Supplies
How do I remove the front turn signal assembly so I can replace the bulb?
Your turn signal bulb is a 1157A or 1156 bulb (either will work), and usually inserts into a connector
that unscrews 1/4 turn counterclockwise, and comes out of a headlight-turn signal assembly on the
front of the vehicle.
Try: opening the hood and turning the bulb holder 1/4 turn counterclockwise, then withdraw the
bulb base and installed bulb. replace old bulb by turning it 1/4 turn counterclockwise and
pulling it out (the 1157A and 1156 bulbs are bayonet-base). Install the new bulb by inserting
into the socket (properly aligning the 2 pins on the base of the bulb with the channels for them
in the socket), and the rotating the bulb 1/4 turn once inserted.
Now - test the new turn signal bulb before putting it back together - this insures that the installation
of the bulb into the socket correctly aligned the (2) contacts in the base of the bulb socket.
Then: insert socket into headlight-turn signal assembly and rotate clockwise 1/4-turn to install.
Summary: remove socket by rotating 1/4-turn counterclockwise and pulling out.
remove 1157A or 1156 bulb from socket by rotating bulb 1/4-turn counterclockwise and
pulling it out
installation is reverse of removal.
Oct 23, 2010 | 1998 Subaru Forester
Eumig 822 sonomatic 8mm dual guage cine projector. Claw fails to engage sprockets in gate. Problem probably due to forgetting about retracting claw when changing formats. Who could service/repair this...
I have a Eumig 824 Sonomatic that needs repair to the claw mechanism, new rotary switch control knob and front sprocket for Super8 mm. Can this repair be effected by you.
Dec 27, 2009 | Cameras
Hi! Got a bang olufsen mx 3000 tv that just gone dead. the red light comes on then i turn it on but that's about it. Do you think its the tube that's gone?
could be the projector bulb is dead. open it up and check the bulb. if it's discolored and burnt looking, you need to replace it. if it's still under warranty, the bulb may be covered- but i doubt it. if the bulb looks good try removing it and re-placing and try again. it may be a little loose, because of thermal expansion and contraction when it cools down. a wee bit of wd-40 can help! i mean, put some on a paper towel, and apply to the threads, or bayonet connector, whichever! if its 'spring loaded', a little wd-40 on the base contact couldn't hurt either! be careful with the wd-40- it's a great contact cleaner, but is flammable!!
so use very little and let it evaporate a little- the bulbs get very hot!
good luck! by the way, the bulbs are not cheap!
Oct 08, 2009 | Televison & Video
I am looking for a free manual for the Eumig Mark 8 Projector. I have an old projector and want to show film of my late mother. Film is original 8mm film 'not' super 8mm. Unfortunately I do not know how to...
was there any chance of me getting a free manual or is this site just a money making idea, obviously if it sounds too good to be true..it usually is!
Sep 14, 2009 | Cameras
DIY lamp
I had the same problem awhile back and looking around for an answer i found this.
http://recklessphilosophers.com/2008/05/02/home-theatre-for-63--dlp-pj-retrofit-for-7-bulb-instead-of-300.aspx
May 22, 2008 | ViewSonic PJ402D DLP Projector
620 people viewed this question
Top Artograph Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Tom Chichester
Are you an Artograph Office Equipment and Supply Expert? Answer questions, earn points and help others
