Question about Sampo DCE-211 Digital Camera
Need instruction manual to operate my DCE-211 Digital Camera manual Focus
Automatic bread maker HB-211 operating manual
You may request a free copy of the manual and recipe book here.
Nov 27, 2012 | MK Seiko HB211 Mister Loaf Breadmaker...
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
Question regarding how to process focus bracket pictures
Focus bracketing is mostly used like exposure bracketing, in a situation where you are unsure of the focus or in tricky situation. You focus normally and the camera will take 3/5/7 shots depending on the camera and you can then examine the shots on a computer and pick the best one. If you want to "blend" the pictures together, that is called focus stacking and is hard to do unless you use specialized software such as Helicon Focus:
http://www.heliconsoft.com/heliconfocus.html
Even with such software, you have to make sure the subject is perfectly still from frame to frame, so a tripod would normally be required.
Also, if all you want to do is get a large amount of the scene in focus, you do not need focus bracketing and focus stacking, simply select a small aperture (large f-stop) and that will increase you depth of field considerably.
Jul 25, 2010 | Canon PowerShot S51S Digital Camera
No download cable
CHECK IF YR USB PORTS ARE FUNCTIONING PROPERLY
Apr 19, 2009 | Sampo DCE-211 Digital Camera
Nikon d40
The G series lenses won't work in AF mode on the newer, entry-level Nikons. They require the DX series.
Jan 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Keep on changing the focus during video capture
As you pan autofocus will try to latch onto a different focal point. Check your manual or go to the Sony Tech support team
Jul 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Focusing Difficulties
1. Typical problem subjects for autofocus 1) Very low-contrast subjects 2) Overlapping nearby and distant objects 3) Very bright subjects in the center 4) Subjects moving very fast 5) Subjects through glass Focus on an object that is at the same distance as the desired subject, apply Focus Lock, and then recompose the picture. Or set the lens focus mode switch to (or), and focus manually. (Manual focus is only possible with cameras providing this feature.) 2. Attempting to take pictures out of the camera's shooting distance: When taking pictures out of the camera's shooting distance, the subject will be out of focus. The shooting distance differs from each camera model. Please check the specifications of your camera in the instruction manual to determine the shooting distance.
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Cameras Logo
24 people viewed this question
Top Sampo Cameras Experts
Are you a Sampo Camera Expert? Answer questions, earn points and help others
