Cannot get internet from router to
Cannot get internet thru router to
digital satellite receiver...I have a Toshiba Laptop hooked up to a Netgear MBR624 router. It works fine. I want to iks satellite receiver to the
internet through the router.
  • 32 Answers
If I understand correctly you want to use the router as a gateway for an sat. receiver.
This Netgear router can be connected to devices that has TCP/IP connections (RJ45) ports or wireless IEEE 803.11 b/g, and that can get the IP address statically or from DHCP (router). Toshiba can do that and therefore it is working fine. If sat.receiver is not device that can behave as a PC (processor etc.) it can not get IP address and router can not "see" that device, therefore router can not let "something invisible" to connect to the internet.
Posted on Sep 13, 2009
My Toshiba Satellite L305-S5921 won't connect wireless or wired to my internet it shows the net works and signals and can be connected to the router but ends up with local or limited service I've reset the...
Try disconnect the router and connect your laptop to the dsl modem. If there is connection then the router may have problems. If the problem persists then go to toshiba service center. They will certainly solve your problem. It might be that there are problems on hardware or drivers.
Jan 30, 2011 | Toshiba Satellite L305-S5921 Notebook
Hello, i have a toshiba satellite laptop with wireless connection. i recently purchased a netgear dgnd 3300 modem/router and have configured it successfully. i have connected my xbox 360 wirelessly and...
Go to the laptop. Open Internet Explorer. In the address bar type
192.168.0.1 or 192.168.1.1
Do you see the new Router or the old one. This is where you set up the connectivity and password. Disconnect your X-Box when setting up the Laptop.
Tips, tricks and videos on setting up in the link.
Home networking explained part 5 Setting up home router
Apr 12, 2017 | Toshiba Satellite M50 Notebook
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
Cant get it hooked up to the internet directly or wireless
If you had it connected by wire, check the side of the computer for a switch. This will torn on your wireless connection.
Oct 27, 2009 | Toshiba Satellite L305D-S5874 Laptop
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Lost all internet connections through NetGear Router
I'm thinking MAC accept/reject list, check to see if it's active or not.
Aug 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Wi -Fi usage in my laptop
Try a third time (every time I go into my own network places for netgear I loose this fixya page -sorry watch for duplication).
Go into "start menu" then click on "my network places" then click on anything that says "netgear router" if its there, click on this and it should bring you to your password for netgear, click this with your password and this should bring you to your main page of your Netgear Router software programing.
Click on "connection status" if it says "success" under "negotiation" then its working OK. If you don't get "succes" then you have problems and I recommend you ring the Netgear service number written in your instruction papers in your old modem/router box they are usually based in Malaysia and very helpful.
Best wishes,
Speedy123
Dec 17, 2007 | Toshiba Satellite A105-S4334 Notebook
Regarding Wi-Fi Usage
yes if the wireless settings are proper see first it is showing the netwok list in your wireless network select the desire network and put the secret netwok key it will start your wireless network .
but make sure you are not remove the wireless lan adoptor driver .this you can see in the control panel ,sytem ,hardware and device manager in network adoptor.
Pc has internet and laptop doesn't with same router.
RUN CMD
IPCONFIG /RELEASE
IPCONFIG /RENEW
AND SEE IF YOU GET AN IP
IF NOT ENTER IP MANUAL
Dec 12, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
