Question about Refrigerators
My ice maker is not making ice. Where do I start the trouble shoot?
  • 4,059 Answers
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Sep 07, 2009
  • 6,784 Answers
The likely culprit will be a damaged inlet assembly
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
The icemaker isn't making ice. any trouble shooting suggestions?
Check freezer temp - has to be at least 10 degrees or less for ice maker to work. Check out ice maker cam motor, water solenoid, tray heater, arm that monitors ice levels, etc.
Apr 08, 2016 | Refrigerators
How do I trouble shoot Dometic Hzb-15s portable ice maker. Powers up but does not do anything else.
first I would make sure it has water hookups, then I would look for the switch that tells it when to start making ice, most likely that is the problem...
Sep 25, 2014 | Cars & Trucks
Ice maker wont work
The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
Jan 14, 2014 | Samsung RS267TDBP Side by Side...
How do I start the cycle on this ice2o ice maker? i have ice in the tray but the ice never dumps in the bin.
Go to page 19 in the Whirlpool Ice Maker Trouble Shooting Service Manual The manual should explain more than you will need on your Maytag/Whirlpool brand refrigerators. If you have questions please let me know, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
Where do I turn ice maker off and on? I have misplaced owner's manual on model gss251frf ww.
Ice makers make ice until the ice bin is full, and as you use the ice, it replaces what is used. This is accomplished by a wire that measures the amount of ice in the bin. The wire moves up and drops the ice and then moves down to measure the ice. If the bin is full, the wire will be held in the "up" position which turns the ice maker off. You can manually lock the wire in the up position and it will never make ice. Releasing the wire will start the ice making process.
Jan 18, 2012 | GE Refrigerators
Ice maker not making ice
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
May 13, 2010 | Refrigerators
Ice maker stopped making ice, it just stopped. There is nothing blocking the outlet, no debris. The water dispenser still works fine but the ice maker is not working. I have a whirlpool 2665 refrigerator....
your ice maker unit is gone bad if you have warenty get them to replace the ice maker if not you need to do it :(
its coast +- 120$ :(
911service today . com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
No water and makes no ice
Check water supply to ice maker. If no water ti water valve on refrigerator, check for water from valve that connects to main water supply. Usually in cellar. If this is plugged, replace with "drill-type" tapping valve.
Nov 12, 2007 | Refrigerators
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
