Question about Whirlpool GHW9400 Front Load Washer
Lights indicate on washer wont start - Whirlpool GHW9400 Front Load Washer
    Brigadier General:
  • 4,088 Answers
Try pushing on the door near the latch area while trying to start the machine. If it starts, but quits when releasing the push on the door, then the door switch probably needs adjustment or replacement. It could also be the actuator pin in the door that presses on the switch is damaged or a little short. Try extending the length of the pin slightly with epoxy or hot glue.
Posted on Sep 07, 2009
Any time I go to start the washer the lid lock button starts blinking and wont start cycle and wont open for ten minutes
Hello. This could indicate a problem with the electric lock. Unplug the washer for a few minutes to reset it and see if that clears up the problem. Have you had a power outage recently(3-4 weeks) prior to the problem? The current surge from the returning power can damage and/or corrupt the programming stored in the main board computer. If you have never experienced the technical part of a washer, please call for service--there are many problems which can cause this symptom. The washer will have to be put into a diagnostic mode to decipher the binary error codes(groups of lights will flash, telling what part of the unit is problematic). I hope I helped you!
Aug 23, 2015 | Whirlpool Washing Machines
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Whirlpool model cae2743bq0 has all lights on and wont start
I just bought four washer and only one of them are working the other three has all lights on and does not want to work at all can someone help me please as the washer were shipped out of the state, desperately seeking assistance???
Jan 20, 2014 | Whirlpool Washing Machines
The door locks but the light goes off and wash cycle wont start
for a front washer turning off the bulb inside the tub just only indicate that the doors is properly lock. also try to check your power source and make sure that you are pressing the on or start button the right way. sometime they need to a long press.
May 05, 2011 | Hotpoint Aquarius WF000 Front Load Washer
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Jul 28, 2007 | Miele W2240 Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
