Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59YX35 Convergance problem, three colors sagging horizontally across top of screen, Auto convergance option not visible at set up menu. tried unplugging for a couple of minutes. (tv has not been recently moved) Is this worth repairing unit less than 2 years old. The convergence option is not available in the "customer" menu or on the "service" menu. I am taking an 84 fault code---"Tube Type Is RP, But Convergence Was Not Detected". I have found a 400mA 125V fuseable link thats bad right next to the flyback transformer. Does anyone know where I can buy a new one online at? Any ideas why it would blow? I'm stationed in England so big screen TV repair shops are hard to find, I'm on my own here. :) Any ideas/info are greatly appreciated.
  • 456 Answers
Just change the picture tube.
Posted on Dec 09, 2007
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    The convergence on this television has obviously developed a problem. The three colors have completely separated. A picture is still visible. I attempted to apply the convergence option from the set-up...
    This RCA tv model use a convergence fuse.The covergence fuse FL231 is dead.U have soldering iron,u can do basic soldering?Try Ebay.com to buy the convergence fuse for the replacement.This FL321 have three fuses,the one in the middle is dead.The FBT,the big black block of plastic,resolder that too.
    Aug 20, 2010 | RCA R52WM24 52" HDTV Projection Television
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    Modle model hd52w67yx66 lost convergance pic has three colors in main menu no convergance option like when new open for sugestions tuner and sound ok
    Thats a easy and inexspensive repair. www.tvrepairworld.com has the RCA repair kit called "ITC222 and ITC222A convergence option missing repair Kit" The kit contains the components and the CD with detailed repair instructions.
    Dec 22, 2009 | Televison & Video
    Rca r52wh74 - no auto convergance
    Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
    Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
    Replacement power board
    NEXT TO THE FLY BACK THERE ARE THREE, (CMT) FUSES THE CENTER ONE IS MORE THAN OPEN. THEY DON'T LOOK LIKE GLASS FUSES, THEY LOOK LIKE CM RESISTOR/CAP LIKE ITEMS. GOOD LUCK.
    Feb 20, 2009 | RCA P52926 52" Rear Projection Television
    Picture(Color Convergence)
    Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
    Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
    RCA HD52W59YX35
    just found the problem fuse that causes this to happen. The set I have also was not converging, and the auto convergences option was also gone. The small fuse labeled fl231 which is right next to the big plastic piece with the large red wire coming from it in the left corner of the circuit board closest to the back. It is the middle of the 3 small fuses that are smaller than a Chiclets gum. I was able to pull up the circuit board and jump the fuse with some alligator clips and the set looked great again. Every one says watch out for the unit with that red wire SO WATCH OUT!
    damortch check out mouser.com I think I found them on there gonna call them tomorrow to see if I can get mine there.
    Oct 26, 2007 | RCA HD52W59 HDTV Projection Television
    Rca d52w23
    if u press menu on remote control and scroll down to set up , press ok and see convergance as an option choose it and adjust convergance.(lines up your colors) if u do this and convergance does not even show on your menu at all anywhere! like mine, then u have an open fuse for convergance board. mine is going to shop for this today.
    Sep 17, 2007 | Televison & Video
    Color bending
    Go into the menu and look for Screen Convergence. It may also have an auto convergance option try that first. If it gives a suto error or you cant adjust it manually the convergance IC's may be bad or a component on the convergance board.
    Sep 15, 2007 | Sony KP-51WS500 51" Rear Projection...
    RCA HD52W59 HDTV Projection Television Logo
    41 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
