Question about Tao XM2go Satellite Radio Receiver
Radio shuts off for no reason w/ or w/out battery, home and car
It just started doing this recently, and I was thinking it was just wearing out. I bought it new in 2005. Any suggestions?
  • dfrankelmsc Mar 24, 2014
    I found it was the battery. They do not last forever, and the original battery it came with was actually recalled by DELPHI. I changed the battery and we are still using the receiver. FYI parts and used receivers are cheap on ebay.
    Problem Solver:
  • 12 Answers
Check "Delayed Power Off" under "Time Set" of Menu. Make sure it's off.
Posted on Oct 26, 2009
Motherboard
I would think its a mother board problem. it could also be a processor or ram problem, as its 8 years old i would think its lasted a good long time. there are meany reason for the motherboard to start to play up. they have smd capacitors inside and over time they wear out and start causing problems or regulator chips for voltage start to wear out. it could even be that its just old. you have done well to have one last 8 years. most you would get 3 to 5 years. so it was well made for its time.
Jul 01, 2017 | Sony VAIO VGN-NR385E Laptop
2003 mustang shuts off, had to jump start.
Have you checked your alternator? Watch the battery guage and see where it is when the car is running. If it's below the 1/2 way mark, you may not be getting enough voltage to keep the battery charged. Otherwise there may be a loose battery cable either at the battery or at the engine. Check the ground wire at the engine block and make sure the positive is tight at the starter. There is also an alternator fuse; check the owners manual for the location.
Dec 04, 2012 | 2003 Ford Mustang
03 ford escape. Please help radio shut off now car wont start
The car did this but now is running fine like nothing happened?? Is this what you are saying??
Aug 18, 2012 | Ford Cars & Trucks
Dash lights flicker when ya turn key and wont start"" (then after you keep turning key serveral times lights quit flashing and car starts" what do you think it could be??
have battery checked, sound like battery weak or battery cables loose or battery post and cables need cleaning has a lot of corrossion.make sure you turn off radio before disconnecting negative battery cable if you decide clean battery cables and battery post,reason for turning off radio to keep from locking out radio play code.have battery tested battery volts should be 12.6 volts.
Feb 01, 2012 | 2002 Oldsmobile Intrigue
The vehicle shuts off while driving after the car has heated up and wont start right away. Had a mechanic clean the injectors and drain all the old fuel thinking there was water in the tank because of the...
could be the distributorless ignition system or coil pack if you have one.start by cking all wire connections for green color acid buildup , also ck battery terminals for white or green buildup.Autos that rellie on computor often have intermittent starting or running problems .
Jan 07, 2010 | 2000 Chrysler Sebring
Mine just started this recently.
Sounds like the battery is not charging. My solution was to use a small screwdriver to move the charger pin in the power adapter hole in the under off center. That gave it better contact, it began to charge properly and fixed my issue.
Aug 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Brand new battery is dead with nothing left on. Bad ground?
Remove positive battery terminal from battery & put a 12 volt test light in line between cable & battery post. As long as 12 volt light is illuminated, you have a draw. Start pulling & re-installing fuses, one at a time,until you see it dim or go out. If it goes out, you found your draw. If it dims, slight draw, such as radio memory etc. if all else fails, make sure you know where they all go, then pull them all, and start putting back one at a time. When light comes on bright, you found the circuit causing the draw.
Jul 03, 2009 | Dodge Intrepid Cars & Trucks
I have been having trouble with my car stereo system
did u properly charge the capacitor before u turned it on if not that could b a problem
Dec 20, 2008 | Kenwood KDC-MP532U
Think there is a battery drain somewhere
Their is possibly a short. I would first isolate the problem. Disconnect the CD player and radio. If you can disconnect it then remove the radio fuse.
Start and drive the car for 15 minutes or so. Shut it off, and let it sit for a while. Then go out and start the car. Repeat this until you are sure that your problem is with the radio or wiring.
If The car fails to start and is having a repeat of the problem you have a parasidic draw on the battery from somewhere.
Dec 09, 2008 | 2004 Toyota Corolla
Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
Tao XM2go Satellite Radio Receiver Logo
141 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
